Tyranny rebuild
To ans your question, Baker's latest generation compensator has a good rep here in hdforums ,but i don't have any 1st hand exp with it.
When the comp went bad in my 09 flhtcu @ approx 10k miles Bakers new comp design was still in beta testing & not avail at the time so i installed HD's SE comp kit that included the new rotor my 09 required along with also installing an aftermarket mod (GMR's " Compensaver " oiling tray) at the same time too.
GMR's compensaver oiling tray is specifically designed to provide additional oil directly onto the compensator which should significantly extend it's srv'c life.
I have approx 9,500-10k miles on that setup thus far with no issues.
Ok,moving on here.
Wow!,from what you stated it seem's as though the IPB went @ 18k miles & then the trans was shot @ 34k miles neither of which should have happened at that kind of mileage under normal op cond which has to be a total PIA esp if it's coming out of your pocket.
Now if an HD is highly modified putting out considerably more power & trq & or is constantly abused those are conditions where IPB & or trans could fail at such low mileage would be a bit more understandable in that situation.
With that said if you dont mind i have a few questions related to the premature IPB & Trans failures your bike had that i'd appreciate if you would answer for us.
* What yr & model is you bike?
* Do you consider yourself an aggressive rider or are you easy on the bike?
* What mfg's oil ,grade & type(std dino/sem,sem-blend/full syn?) did you run in the primary case & Trans?
* Did you follow HD's rec to change the oil in the primary case @ 10k miles and trans oil @ 20k miles?
* If you didn't follow HD's rec maint schd/mileage for changing oil in the trans & prim case what mileage sch'd did you change the oil in trans & prim case at?
Thanks....Scott
People pull their hair out trying to get it exact ,, if I measure deflection at the slackest point, using the gauge set at 10 pound between the third and fourth line , I'm good to go .... When your up and running , the belt will tighten with heat/friction etc, and the tightest point on the belt wont be like a over tightened guitar string !!!!
