Misfiring
Old May 30, 2016 | 06:27 AM
lp's Avatar
lp
What cams?
It should not misfire with or without the correct fuel map.
No cam changes the timing or fuel requirements THAT much to cause a straight up misfire.
Will it run strong as it should? No, but it should fire on all cylinders - always.
Depending on the cam it could presently be running lean or rich but STILL... both cylinders will fire.
Timing may not be optimal but you are talking minor degrees and again it will still fire.
At idle, all timing and fuel requirements are near identical for every cam ever. If it's misfiring at idle you should check Cam timing and pushrod length as already mentioned.
Old May 30, 2016 | 08:08 AM
rusty289's Avatar
rusty289
Not to sound stupid but are you sure it's misfiring and not just running rough?
New cam can make it run pretty choppy without being tuned.
Nick92591
Aug 12, 2018 08:22 PM
Nick92591
Aug 11, 2018 11:52 PM
Campy Roadie
Engine Mechanical Topics
19
Jun 20, 2017 06:12 PM
WideGlideFever
Jul 28, 2015 02:00 PM
biz44
Screamin Eagle CVO Models
Jan 26, 2011 03:42 PM
