No front brake, handle doesn't move either.
Old Jun 1, 2016 | 11:13 AM
KWC6's Avatar
KWC6
Default No front brake, handle doesn't move either.
Went out this morning to start my 2011 Ultra, squeeze front brake handle and it will not move.. Brakes are not locked, just the handle. I wonder if it is the ABS system busted. Called dealer and they are sending a trailer. Damn.
Old Jun 1, 2016 | 11:14 AM
crazytown's Avatar
crazytown
I hate to ask what may be an obvious question, but do you think it may just need some cable lube?
Old Jun 1, 2016 | 11:15 AM
nevada72's Avatar
nevada72
hydraulic brakes
Old Jun 1, 2016 | 11:19 AM
TinCupChalice's Avatar
TinCupChalice
There was some debate on this very topic HERE
Sorry to hear of your troubles; I hope you can get the problem resolved and back on the road soon
crazytown's Avatar
crazytown
Originally Posted by nevada72
hydraulic brakes
Ahhhhh... well, there ya go then.
Old Jun 1, 2016 | 11:35 AM
KWC6's Avatar
KWC6
Thanks.. I have exactly what is described in your attachment.. Frozen HCU.
Another $600 most likely to fix, when they can get the parts.
Old Jun 1, 2016 | 11:44 AM
GTK's Avatar
GTK
Most likely the Brake Control module.If it is,its important to find what caused the failure.Most BCM's fail due to brake fluid contamination and not a electrical malfunction from what I have researched.Moisture is the worst culprit.JMHO
Old Jun 1, 2016 | 11:55 AM
Bumpandrun's Avatar
Bumpandrun
cheaper to toss BCM in trash.
Old Jun 1, 2016 | 12:34 PM
SBates08's Avatar
SBates08
I wonder if it would be possible to run brake lines like a non abs bike using your existing master cylinders.
Old Jun 1, 2016 | 12:37 PM
Vernal's Avatar
Vernal
I bet you meant ABS not BCM
