Engine light comes on...
Old Jun 1, 2016 | 08:32 PM
JonGolden's Avatar
JonGolden
Default Engine light comes on...
Ok. I've got a 2010 ultra with 18k. As I was pulling away from work, my engine light came on and I lost throttle power. I stopped, turned it off, started it again, and let it warm up, then went off again. Went fine for a few miles, then did it again. Repeat. Started backfiring and lost throttle power. Repeat. Started back up and kept RPMs under 3 and seemed ok. Just did a 15k service on it. Any thoughts what could be going on?
Old Jun 1, 2016 | 08:37 PM
tibadoe's Avatar
tibadoe
Need to check for codes. It must have went into Limp mode.
Old Jun 1, 2016 | 08:42 PM
Nute's Avatar
Nute
Suspect connection on back of throttle housing bad connection. Common problem & HD has a Tech. Bulletin on this very subject. As stated above check codes. DTC codes P0120, P0122, P0123, P0220, P0222, P0223will indicate this.
Old Jun 1, 2016 | 08:47 PM
JonGolden's Avatar
JonGolden
Originally Posted by Nute
Suspect connection on back of throttle housing bad connection. Common problem & HD has a Tech. Bulletin on this very subject. As stated above check codes. P11** code will indicate this connection.
How do I check code?
Old Jun 1, 2016 | 09:02 PM
bdtaylor1979's Avatar
bdtaylor1979
http://www.fuelmotousa.com/p-29661-h...ble-codes.html
OPDSam30
Apr 27, 2013 07:13 PM
roadcapt
Jul 1, 2012 11:54 AM
09rkpolice
Sep 18, 2011 11:35 PM
Allen Dye
Jul 16, 2011 04:32 PM
WNMORE
Jul 19, 2010 12:00 AM
