stalling at stop
Old Jul 6, 2016 | 10:03 PM
  #41
svarnster's Avatar
svarnster
ohm tested engine temp sensor and it checks out good
Old Jul 6, 2016 | 10:11 PM
  #42
Skogdog's Avatar
Skogdog
Originally Posted by 151fire
I was having issues similar to OP this past week or two, replaced Engine Temperature Sensor and have not had any issues since, I think that part was like $38 so if anything it's a good place to start!
Ditto--'10 SG. Ran fine at highway speed, but around town it would die if not throttled, and it would blow black smoke (rich). Often would rev to 3K and gradually come down. The computer was going bonkers trying to adjust to the engine temp sensor failure. It apparently ignores those signals at highway speed. Forty bucks and twenty minutes later, all golden. Threw a bunch of codes too...confusing.
Old Jul 6, 2016 | 11:08 PM
  #43
svarnster's Avatar
svarnster
yes very confusing I am not getting any codes. did u do an ohm test on the sensor? if so did it fail the tests or read good. I checked mine and all the test ice water was 9.750k and boiling was right on also. when yours would act up could u cut it off and crank it back up and it run right again?
Old Jul 6, 2016 | 11:18 PM
  #44
svarnster's Avatar
svarnster
[QUOTE=howitzer88;15214753]No codes showing for my bike. I'm gonna start with replacing the engine temp sensor.[/QUO
Old Jul 7, 2016 | 07:12 AM
  #45
im's Avatar
im
Review these two area's.
Do not purchase anything untill you test it.
Idle speed control actuator 27272-95a
Also, any chance at all that you touched or something was near the wires for the crank sensor (starts near oil filter) or some melting going on with cam sensor (in the cone).
I will guess that when this happens you have the clutch pulled and are giving no throttle.
Since the engine is at zero throttle then it must drop to idle but instead it stalls unless given some gas.
Go look at the Idle speed control actuator 27272-95a for movement.
Old Jul 7, 2016 | 08:05 PM
  #46
svarnster's Avatar
svarnster
yes clutch pulled in and it dies down. I checked the isca and it is functioning, I adjusted the warm idle up to 1050 and it helped but bike acts like it is on 1 cylinder at this point and it is affecting the bike through the rev range, I can feel the bike being held back like it is not breathing properly. I put a spark tester on it rear cylinder then front, when it is dying it is still sparking like a champ on both cylinders. bike seems really hot on the rear cylinder. it was 240 on rear and 200 on front. after a few minute while I found the thermometer.
Old Jul 7, 2016 | 08:06 PM
  #47
svarnster's Avatar
svarnster
I plan on checking cam crank sensors when it cools down also gonna pull plugs again.
svarnster
Jul 14, 2016 09:04 PM
madzac37
Jun 14, 2011 12:32 AM
kansaskid72
Sep 2, 2010 12:00 AM
Adacas
Oct 28, 2008 10:37 PM
streeteagle
Aug 13, 2008 04:13 PM
