So how much fluid to you add? Notice another poster referred to a "wet fill" v a "dry fill." I don't want to over or under fill. And I don't know how to check the primary level. So again, HELP!
Thanks guys
I fill to a level with the bike straight up as described in this picture.
Thanks guys
Don't get hung up about the precise quantity, just make sure you have enough oil to hand, which a fresh bottle will provide. Then fill to the correct level, as shown by Mike above. The quantities in the manual are only for guidance, the correct level is the final decider!
Btw,,,I have found the best thing to put under the bike when you are going to do something messy is a couple of puppy training pads. They are very absorbent and don't leak through. You can buy them at any pet store.
Tip of the day!
That's actually not a bad idea at all for any fluid dripping problems.
