volume button issue
Old Jun 7, 2016 | 03:59 PM
Redneck4409ckf's Avatar
Redneck4409ckf
Default volume button issue
So pretty sure it's a ground issue, but installed Kenwood deck, aswc-1 Metra kit with a 99-9600 install kit, everything works great except the volume button. It will work most the time but there is some times that it won't turn down via hand controls. Plus if I press the volume button it will change the radio station. ..pretty sure it's not suppose to do that, anyone also think it's a ground? I replaced the ground to the triple clamp just fyi
Old Jun 7, 2016 | 04:20 PM
mike_oh's Avatar
mike_oh
I never could get that kit to work on my bike. I went with Hawg Wired and am very pleased!!
Old Jun 7, 2016 | 05:10 PM
Redneck4409ckf
Yea sometimes it works awesome sometimes it doesn't at all...pretty irritating
Old Jun 7, 2016 | 07:28 PM
mike_oh's Avatar
mike_oh
I had the same kit and it was all wired correctly. Could not get it to recognize my head unit. Called them and tried everything before I gave up. The Hawg Wired is truly plug and play and really works! Very well made.
Old Jun 7, 2016 | 07:36 PM
SBates08's Avatar
SBates08
Move the ground off of the triple tree. I had the same issue. Moved it to the ground on the amp and fixed the problem.
Old Jun 7, 2016 | 07:39 PM
mike_oh's Avatar
mike_oh
Good advice. I did that and never could get it to work even using the ground from the battery. Good luck!
Old Jun 9, 2016 | 10:41 AM
Redneck4409ckf
So...hooked it up to my amp last night...now the volume goes up automatically...which is why I switched this HU from the stock one in the first place. Now I'm thinking I should take that pink/white wire off the amp ground now...it worked fine before but was just acting up, before It would just go up when I was on the throttle, but not at a stop light, tested it today, even at a stoplight it raises the volume...is it still a ground or do I have another issue going on from the stock HU?
Old Jun 9, 2016 | 11:05 AM
SBates08's Avatar
SBates08
Contact member "AAWAV". He can help you troubleshoot that Metra better than anyone I know.
Old Jun 9, 2016 | 12:29 PM
roussfam's Avatar
roussfam
And I on the other hand am pleased with the Metra setup and price was right
Old Jun 9, 2016 | 12:33 PM
Redneck4409ckf
Apparently I have to upgrade my membership to do so
