Scissor Jack Close Call
Old Jun 14, 2016 | 06:47 PM
nytryder's Avatar
nytryder
Originally Posted by PeteF
Glad you weren't under it. I've got to say I would not have expected that with a scissor jack.
Same here. Never seen or heard of that ever. Glad you're ok.
Old Jun 14, 2016 | 06:57 PM
glcash's Avatar
glcash
I have a Titan scissor jack. Never had a problem with it and I also use the safety pin as security. I have left bikes on the jack for weeks at a time.
Old Jun 15, 2016 | 01:46 AM
mcain49's Avatar
mcain49
I have a Black Widow scissor lift that I have used the **** out of for 2 years and its never missed a lick. The one I have is wider than the one shown in the picture and has a dolly pan with rollers. I use it primarily for raising the front or back end for cleaning, making adjustments, belt tension, etc. It will lift my Ultra completely off the ground with no problem, (done it once) but I would not be comfortable using it that way unless I had nothing else. Lift rating is 1100 lbs and lift height is 15". Great little lift for minor maintenance work that takes up little storage room, fits under the lowest bike, is simple, reliable, and safe to use if you understand its limitations. Although the lift can do it, I would have serious reservations about using this lift for raising a big bike with both wheels off the ground at its maximum height and moving it around on the rollers.
Old Jun 15, 2016 | 05:13 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Just Google "scissor jack failure" and look at the threads and the numerous published engineering studies of their propensity for failure". Scissor jack failure is far from an unusual event.
hyrax222
EVO
13
Mar 21, 2015 07:43 AM
Cousy
Mar 17, 2011 12:12 PM
mudbeast2
Feb 9, 2010 10:13 AM
eja
Dec 30, 2009 09:07 AM
ph0neman
Apr 23, 2008 04:52 PM
