87 Electra Glide Charging Woes
Old Jul 6, 2016 | 09:26 AM
14GuineaPig's Avatar
14GuineaPig
Pull the tail light lens off. The brighter of the 2 elements in the bulb should be for the brake light. If it stays on all the time most likely one of the brake light switches is defective. The easiest switch to disconnect is the rear/foot switch. If you pull one wire of the switch and the light remains on then the front switch is probably causing the problem. The front switch is located in the right hand handlebar control. It is a mechanical switch that is triggered by movement of the brake lever and usually very easy to break. The rear switch is usually a pressure operated switch activated by the pressure of the brake fluid when the pedal is depressed.
Old Jul 6, 2016 | 10:08 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
When replacing any charging system components, we use/stock Cycle Electric here.
Steer clear of the Chinese stuff.
Scott
Old Jul 6, 2016 | 11:03 AM
Scott in NY's Avatar
Scott in NY
6th Gear
I pulled the foot switch wires, (passenger side bottom center) and the light stayed on. (I did pull the lens to verify both elements are light. One being brighter) THEN i unplugged the foot switch. No change. I volt tested both wires and both show 12 volts in it. The hand brake switch would make sence if its stuck..12 volts would still run both ways. Also, i never use chinese of aftermarket parts on the Harley.
Napalm Dog
Aug 26, 2014 05:11 PM
bikercouple
Mar 25, 2014 06:18 PM
berndog
Shovelhead
Jul 11, 2011 03:52 PM
FLHXXHLF
Feb 6, 2010 03:14 PM
geedub
Aug 28, 2008 08:01 PM
