Torque & Back Pressure, how does it work
Old Jun 30, 2016 | 12:38 PM
slowrollin's Avatar
slowrollin
Default Torque & Back Pressure, how does it work
So, I was debating on going back to my stock head pipe because our friends a Fuel Moto said the problem I experiencing was caused by Dresser Duals not creating enough torque at lower RPM ranges and suggested my stock head pipe would be better than what I had. Turns out, they were correct. The stock head pipe is working better for me. Then one of the guys at the shop mentioned that there wasn't enough back pressure in the true duals. He didn't have time to give me a lesson on what that meant, so I figured I'd ask my buddies on the forum. Are the back pressure the shop mentioned, and the torque Fuel Moto mentioned, one and the same, or is one the result of the other?
Thanks!
Old Jun 30, 2016 | 12:47 PM
RG Pilot's Avatar
RG Pilot
Simply speaking, back pressure happens when the exhaust can't flow out as fast as the piston comes up on it's exhaust stroke so it compresses slightly on the exhaust stroke and the velocity increases as it exits (venturi effect) creating lower pressure which allows more of a charge to be pulled into the cylinder during the intake stoke. So with lower back pressure as the true duals have, you'll sacrifice low end torque for higher RPM horsepower because of a more free flowing exhaust but our bikes aren't used so much for top end and that's why most feel that low end torque is more important to them. I agree with that.
Old Jun 30, 2016 | 12:50 PM
slowrollin's Avatar
slowrollin
This is where the Torque comes in?
Old Jun 30, 2016 | 01:16 PM
RG Pilot's Avatar
RG Pilot
Correct. The cylinder is able to get more of a fuel/air charge at low RPM when throttle is applied. Exhaust gasses are evacuated more completely when there is some back pressure at low RPM due to scavenging of the gasses cause by the venturi effect. Sounds counter-intuitive but basically, that's what happens. Then as RPM increases, flow also increases so less back pressure is best for high RPM and that's where horsepower comes in. Cam profiles have a lot to do with this as well.
Old Jun 30, 2016 | 01:26 PM
HardRider1's Avatar
HardRider1
Here is a great explanation of the "Scavenging Effect" caused by back pressure
File Type: pdf
Old Jun 30, 2016 | 03:30 PM
qtrracer's Avatar
qtrracer
back pressure helps nothing. search around and get some answers from exhaust experts.
Old Jun 30, 2016 | 03:57 PM
HardRider1's Avatar
HardRider1
I disagree, without sufficient back pressure the exhaust gas velocity will not increase enough to create negative pressure in the combustion chamber before TDC, which in turn ensures all exhaust gases are evacuated as well as helps pull vaporized fuel in during the valve overlap.
Old Jun 30, 2016 | 04:01 PM
bettingpython's Avatar
bettingpython
http://www.hotbikeweb.com/custom-mot...nical-analysis
Read and be educated.
It's all about velocity, expansion, volume and resistance, not back pressure, smaller pipes equals less expansion room which aids in velocity, too much expansion room and you slow the gas flow down, too much and get reversion. Also going true dual you lost the scavenging effect where high speed exhasut pulse from 1 cylinder creates a low pressure void at the collector which helps pull the gasses out faster.
Old Jun 30, 2016 | 06:40 PM
0ldhippie's Avatar
0ldhippie
Exactly! Ya want back pressure stick a potato in the pipe. Correct reversion is what you should be after...
Old Jun 30, 2016 | 06:42 PM
Chekoz77's Avatar
Chekoz77
