Ping with Sudden Throttle
Old Jul 6, 2016 | 07:34 PM
checkers's Avatar
checkers
Originally Posted by wscott
Not a bad rec at all that may in fact reduce or stop the ping .
But that will likely be a temporary fix because a few k miles later carbon will already be building back up in the comb chambers again and the ping will return sooner then later in summer heat.
Heat is a big factor when talking detonation esp in an air cooled hd motor in extreme 98deg f heat so running a healthy dose of techron (Concentrated version is best!) is never a bad idea to do 2x-3x maybe even 4x yrly depending on mileage riden.
Doing that should maintain clean injectors & comb chambers in an EFI HD that ensures a better smooth running motor with max perf at all times.
I run a healthy does (1.5oz's per gal fuel) of Techron's concentrated version right before every motor oil & filter change on my HD which equates to approx 2x yrly for my bike.
But if you want to address the real issue in this case of an air cooled HD motor suffering heat related issues & detonating in 98deg f addressing the heat issue is what to go after which at the same time results in multiple improvements in engine perf & overall rider comfort @ the same time too like i rec & posted earlier in this thread.
Happy Motoring.
Scott
The last couple posts here are correct. Make sure you get the Techron concentrate. Carbon is a cause of many drivability issues on TC's. Clean up does not have to be temporary. Corn gas, carbon, high temps and low rpm's are inviting a ping. Clean the carbon with this product on every few tank fills, ride the motor at proper to high rpm range at all times, wind it up. Cool the engine with the several ways mentioned prior. Route your internal crankcase breathers to the outside, stock A/F or Stage 1. Injesting dirty hot oil mist into engine, guess what? Yes carbon. Keeping combustion chamber clean is an easy ongoing process. The way your twin cam runs will be improved.
Old Jul 7, 2016 | 04:17 PM
vizcarmb's Avatar
vizcarmb
I had that same issue. Called the dealer, and the dealer told me not to do that. Especially at low rpm. Recommended the roll on method. He was telling me regardless if it was tuned properly it will still ping if you do a Wide Open Throttle at low rpm
Weird right???
Old Jul 7, 2016 | 04:32 PM
qtrracer's Avatar
qtrracer
Originally Posted by Highwayman-AL
Only pure gas I have come across was at The Home Depot for yard equipment and I don't think it was unleaded and was pre-mixed with oil.
I can try the Techron though there are auto part stores all around.
Gas type has ZERO effect on ping.E-10 is perfectly fine. Just use the highest octane possible in your case.
Old Jul 7, 2016 | 06:15 PM
Hammz's Avatar
Hammz
Gas type DOES have something to do with spark knock (ping). Running a winter grade fuel (high RVP) in high ambient summer temperatures will intensify any tendency for knocking. Changing to a lower RVP fuel (summer grade) will lessen chances for knock. The fuels in different regions of the country and at different times of the year will vary significantly. E10 will actually have a higher RON than the base stock it is blended with, so it can decrease the knock, providing the engine sensitivity to RON is higher than sensitivity to A/F ratio (E10 runs a bit leaner in engines w/o O2 sensors, ie open-loop systems).
Spent 35+ years working in fuels & lubricants research. Did a lot of "octane testing" in the automotive industry before the incorporation of knock sensor technology into engine management scheme.
Old Jul 7, 2016 | 06:22 PM
qtrracer's Avatar
qtrracer
Octane is the resistance to knock, they should taught you that on your 1st day 35+ years ago
Old Jul 7, 2016 | 06:26 PM
Hammz's Avatar
Hammz
Your point is?
Old Jul 7, 2016 | 07:25 PM
Hammz's Avatar
Hammz
FYI for qtrracer:
RON is determined using a CFR engine per ASTM procedures. A fuel with a 100 RON rating has the same resistance to knock as iso-octane fuel. Normal-heptane is the other end of the scale. A fuel with a 93 RON has knock resistance equivalent to a blend of 93% iso-octane and 7% normal-heptane.
There is a separate ASTM procedure that defines criteria for determining the MON (motor octane number), which is generally 8 to 12 numbers less than the RON and is defined as that fuel's sensitivity.
The octane numbers posted on gas pumps are the average of the RON & MON numbers [ (R+M)/2 ]. When a manufacturer recommends a 93 RON fuel, a gas pump rating of 91 average rating will generally satisfy the recommendation.
EasTexUltra12
Jan 24, 2014 08:13 PM
danzio
Sep 3, 2012 09:43 AM
VTGlideRider
May 3, 2011 06:21 AM
rbabos
Jun 21, 2008 08:54 PM
Papamte
Sep 28, 2005 10:02 AM
