Chain drive conversion
Old Jul 10, 2016 | 08:38 PM
Egldr05's Avatar
Egldr05
Hmm, No noise, I've adjusted my chain twice in the last 15K+ miles, lube it a couple times a year with chain wax, and the brake caliper side of my rear wheel is much dirtier than the chain side...and that's with low dust pads.
Old Jul 10, 2016 | 08:43 PM
Egldr05's Avatar
Egldr05
Originally Posted by penmaker
I'm just curious. Not questioning you, just curious. Why would you want to go to chain drive from belt drive?
For me running a 120" motor (and I like to use it) I like the peace of mind it gives me when I'm far from home or a dealer. If I should break a chain (not likely) I can fix it on the side of the road in a half hour. Break a belt while on a trip you're looking at a tow plus most likely a $700+ bill.
Old Jul 11, 2016 | 05:29 AM
bettingpython's Avatar
bettingpython
Modern O ring or X ring chains do not suck. Maintenance is as easy for them as it is for a belt.
Old Jul 11, 2016 | 09:48 PM
HDSAE60's Avatar
HDSAE60
IMO chains are messy and a PITA to maintain.
Old Jul 11, 2016 | 09:57 PM
bikerlaw's Avatar
bikerlaw
I'm gonna go out on a limb her and say that he is probably building an engine that's gonna snap a belt in little or no time, at all.
Old Jul 11, 2016 | 10:32 PM
Bumpandrun's Avatar
Bumpandrun
Chains now. No noise. No mess. Some of us are putting 150-200hp+ to rear wheel and belts are pretty marginal. Plus chains let us run bigger rear tire with more clearance .. But I don't think the OP asked about opinions on belts. Just chains.
Old Jul 12, 2016 | 05:42 PM
vistavette's Avatar
vistavette
Originally Posted by Tom84FXST
People that say this have never had a bike with a modern o-ring chain.
First, o-ring chains do not need to be lubricated, just occasionally cleaned...the lube is inside the rollers, and the o-rings keep it from getting out...putting lube on the outside just attracts dirt and wears the chain out sooner.
After the break-in stretch, they require very little adjustment..I adjust mine once a year.
If you can hear the chain over the exhaust...you need louder exhaust
Are you sure about this? My 2014 Triumph Tiger XC has either an o or x-ring chain and my owners manual wants it cleaned and lubed every 250 miles! I don't do it that often as I don't ride off road and it never rains here so it never sees water but I sure get to it every 500 miles at least. Chains really do suck. PITA. The belt on my '09 Ultra now has almost 74,000 miles of trouble and maintenance free riding. I check it to make sure it's in spec and not cracking but I'd never trade the belt for a chain.
Old Jul 12, 2016 | 11:49 PM
wolf1340's Avatar
wolf1340
Reason I want a chain is that I don't want to be stuck along the road on a trip with a broken belt. Chain I can fix along the road. And I've seen lots of bikes snap belts putting out less power then I plan to put out. I snapped a belt before on an 04 that had a wider belt. And, I was only at 130hp/tq. I don't want to worry about snapping a belt so I'm going to chain since I got everything apart. I'm planning to be in the 160 hp/tq range.
Old Jul 13, 2016 | 04:55 AM
ddm502001's Avatar
ddm502001
I have owned all three variations, old series chains with engine drip oilers, o-ring chains, and belt drives. Had a friend with a nitrous set up on a built S&S engine, could wipe teeth off a belt(using N wrong). belts require removal of primary to fix, chains do not, chains AND belts require periodic inspection and adjustments, chains will not stone cut as a belt can and has been seen by me.
If I had a preference, and expense not so high I would go back to chain, just so I could change it at home in the thirty minutes the old ones took when it became worn out. O-ring chains do need external lube where the sprocket contact is but there are dry lubes out there much better than oils.
Sauraus
Jan 10, 2025 04:23 AM
MadMario111
Jan 29, 2020 06:58 PM
fcc75
May 2, 2019 02:09 PM
Bohemian
Nov 24, 2013 08:25 AM
Jasper86
EVO
19
Mar 6, 2013 08:34 PM
