Experiment halogen bulbs
Old Jul 11, 2016 | 07:54 PM
SnoRider's Avatar
SnoRider
Default Experiment halogen bulbs
I have been reading to find some halogens, thinking ultra silver stars or PIAAs, looked at ZXEs...not sure on them but came across this study a guy did in his truck measuring with a light meter. Take a look
http://www.silveradosierra.com/electrical/piaa-vs-silverstar-ultra-vs-stock-t22542.html
Old Jul 11, 2016 | 08:35 PM
TXNT's Avatar
TXNT
I converted my softail (4" housing) to a PIAA, still not bright enough so I went to an HD Daymaker. Recently purchased 2012 Street Glide with larger light housing, did not think it was bright enough so I replaced the stock bulb with the PIAA previously used in the softail and aimed it a little bit highter. BIG difference between PIAA and stock. I think I will keep the PIAA in the SG ilo purchasing another daymaker. The larger housing definetley gets more light out there.
Old Jul 11, 2016 | 08:49 PM
ORradtech's Avatar
ORradtech
I used to run Silverstars in my truck. Light output was better but I couldn't get them to last much over 3 months. GE was good about replacing them but I finally gave up on them. They just wouldn't last.
Old Jul 12, 2016 | 05:24 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Graph the data. Look at the trend lines. If the data follows what he's already gathered, at less than 10 foot distance the stock light would have a higher lumen than either the Ultra or PIA. For the Ultra and PIA bulbs are dropping lumens at a steeper rate with regards to distance than the stock bulb is.
A lumen value at the lens, 2 feet away and 5 feet away is not what you drive with at night. Much more significant would be the lumens at say 100 feet. I would be very curious to see what that data point would have shown. But, it was not measured.
Old Jul 12, 2016 | 06:43 AM
todd-67's Avatar
todd-67
I have had good luck with PIAA over the years and my experience with the sylvainia's was short life as stated above.
Old Jul 12, 2016 | 10:37 AM
SnoRider's Avatar
SnoRider
They study was not done as I would have done but at least he used a light meter. Those meters also have multiple settings for different type of analysis which wasn't really discussed in the study, along with positioning of the sensor. I would be more concerned with ft candles instead of lumina though. I think they study used lux. Readings should have been taken at further distances as well as along different planes. When I get all my gear...and do the install I will do a proper light study for us with my meter.
ghoticov
Dec 21, 2013 09:16 PM
dennyo
Oct 18, 2013 09:05 AM
T K Glider
May 13, 2011 12:24 AM
joflewbyu2
Nov 21, 2010 09:25 PM
OldFenderGuy
Jun 11, 2006 08:12 PM
