Ignition Switch Capacity
Old Jul 13, 2016 | 06:31 PM
SnoRider's Avatar
SnoRider
I like the relay and agree it's the safest option, But to go back to the original question, if the ignition switch has capacity to power that 15a P&A fuse what's the difference between hooking up lights vs plugging a heated jacket into the accessories outlet? As long as my lights stay under 15a my ignition switch should be capable correct?
Old Jul 13, 2016 | 07:26 PM
Vernal's Avatar
Vernal
That's how most have done it but is it the best way, no.
https://www.hdforums.com/forum/touri...igh-beams.html
Old Jul 14, 2016 | 01:55 AM
RKZen's Avatar
RKZen
Agree most have used post #6 on that thread. Others have used the HD harness P/N 69200441 for the fairing bikes or 69200442 for the Kings and Softails w/ aux lights..
Old Jul 14, 2016 | 03:45 PM
SnoRider's Avatar
SnoRider
Yeah, I like the way I did it. No cut and splice, no adding extra crap...just swap the two wires and run the passing lamps off P&A....if the P&A can handle 15a run through the ignition switch I don't see why I would need to put a relay in just because I am hooking up lights, I just need to stay below 80% of the P&A capacity. Hell, the MOCO runs the passing lamps through the ignition switch with the harness design...and you can still run the 15a to P&A.
jcmoran1
Electrical/Lighting/Alarm
Aug 28, 2015 07:19 PM
Ndoggct
Apr 5, 2015 11:09 PM
IronWright
EVO
Jul 29, 2012 04:39 PM
Gustapo
EVO
Jun 12, 2011 01:54 PM
Calwoodbutcher
EVO
Sep 22, 2010 01:31 AM
