21 18 Wheel Conversion
Old May 21, 2007 | 09:35 PM
Gunsmoke's Avatar
Gunsmoke
Default 21 18 Wheel Conversion
21 18 Wheel Conversion does it improve the handling on a RK and what changes do you have to make to pull it off?
Old May 21, 2007 | 10:22 PM
IceHeritage's Avatar
IceHeritage
Default RE: 21 18 Wheel Conversion
1) The handling is a little more responsive
2) Non just install and Ride
Old May 21, 2007 | 11:05 PM
lkr0's Avatar
lkr0
what he said
ORIGINAL: IceHeritage
Old May 21, 2007 | 11:17 PM
04harleyboy's Avatar
04harleyboy
I lowered my front end 1" to compensate for the 1.25" the larger wheel raises the front. (this is only a suggestion, I do not think you have to do this) The fender may need to be modifed slightly, I had to elongate the rear holes of the fender to get the proper clearance. I used a nut taped to the wheel to make sure I had .250" clearance.
I thought the handling improvements were dramatic on my bike, probably about 50% due to the Metzler tire design, and the rest due to the shorter sidewall of the tire / larger wheel diameter.
Go for it, you'll love the improvement, and the look
Old May 22, 2007 | 01:06 AM
Gunsmoke's Avatar
Gunsmoke
Thanks for the tips the 21 18 hadn't really hit in Lou, KY yet but it's coming I plan on having my hog right you know!!!!
Old May 22, 2007 | 09:25 AM
04harleyboy
LOL, Yeah, I've only seen one other set here in Michigan so far.....I'm sure there are more to come
Old May 22, 2007 | 01:18 PM
IceHeritage
I wish i could say the same thing for Cali, everywhere you turn you see 21 x18 Mostly Mags not to Many Wires
Old May 22, 2007 | 01:33 PM
lkr0's Avatar
lkr0
getting this way in ATL too.
Old May 22, 2007 | 01:46 PM
BadX's Avatar
BadX
I just went 18-18 and after I did it wish I would have gone ahead with the 21-18 but I am very happy with the new look and dont have those damn spokes to clean any more
Old May 22, 2007 | 02:21 PM
Firetender's Avatar
Firetender
Definitely the last thing I'd modify on my FLHR. If I wanted a taller skinny tire to distribute less weight across the road, and catch more lines off the superslab, I'd be riding a Wide Glide.
