Battery Tender USB charger
Old Jul 26, 2016 | 11:17 AM
Whodey's Avatar
Whodey
Default Battery Tender USB charger
I put a USB charger, that plugs into the quick connect on batter, on my 16 RK about a month ago. It worked great for a while but now I am showing alert on phone that I am connected to a slow charge. I am using the Samsung cable that came with phone.
Old Jul 26, 2016 | 01:44 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Try a different cable. They do go bad.
Old Jul 26, 2016 | 05:08 PM
dandrumheller's Avatar
dandrumheller
not sure why it would have worked for a while then all of a sudden started showing slow charge warning - did you recently get a software update on the phone? If not, the cable going bad, as suggested above, may be the culprit.
However, it is my understanding that the battery tender charger only puts out 1 amp. That's not enough juice for many of the more recent phones to charge at full rate. 2.4 amp chargers make them happier.
Old Jul 26, 2016 | 05:23 PM
Beaux's Avatar
Beaux
Nothing charges my phone faster ..................
Battery Tender USB Charger
The Battery Tender USB Charger plugs into your SAE battery harness and charges USB devices via a 5V/2.1 AMP output.
Old Jul 26, 2016 | 06:34 PM
dandrumheller
I stand corrected. Thanks for this info.
Old Jul 26, 2016 | 07:27 PM
CJeep's Avatar
CJeep
If it not your USB cable, check the tender connections at the battery. They may be loose or corroded.
Old Jul 26, 2016 | 08:20 PM
CJeep's Avatar
CJeep
Also, found the thread I did a while back. Soldered a SAE connector to a USB port. Plug it in when I need it to the tender lead. Charges my phone fast. Its at least 2 amps.
https://www.hdforums.com/forum/dyna-...-i-did-it.html
Old Jul 26, 2016 | 09:00 PM
Onedef1's Avatar
Onedef1
The power port ("car charging port") puts out more amperage than the USB; I had the same problem and switched to a 3a car charger. Charges like a beast now.
But yeah, I echo the suggestion that you get a new cord. They do go bad for no reason at all, sometimes.
EDIT: oh wait... I thought this was about the storage port USB... Never mind me, then. My apologies.
Prot
EVO
22
Dec 8, 2015 02:35 PM
goofey
Mar 13, 2015 07:26 PM
dmathieu
Jan 27, 2012 07:23 AM
CasaWolves
Mar 8, 2010 11:17 PM
Hidalgo
Jan 6, 2008 12:25 AM
