Antenna mount help
Old Jul 31, 2016 | 03:31 PM
ORradtech's Avatar
ORradtech
An inadvertent pinch or pull could break or ground the center conductor. An Ohm meter will tell you.
The tall rear antenna should give you the best signal once you sort out the wiring.
Old Jul 31, 2016 | 05:10 PM
Cozz's Avatar
Cozz
Changed out the wire in question. Everything works great. Haven't had a radio that worked correctly since November when I removed the tour pack. This is nice . Thanks to all that responded.
Old Jul 31, 2016 | 05:53 PM
WP50's Avatar
WP50
Did you find a problem with the wire in question? I'm guessing ya mean the antenna cable. Or did you just give it a shot and it worked?
If timre permits could you elaborate on how you made the mount.
WP
Old Jul 31, 2016 | 06:24 PM
Cozz's Avatar
Cozz
Default Antenna wire
The antenna wire from the radio to under the seat was bad. Probably from old age and how I had it wadded up under the seat. Went up to advance auto and got a slightly shorter replacement for five bucks.
The bracket is just a piece of mild steel, with a quarter turn twist, so it can mount on the saddle bag bracket vertically, then turn horizontal to hold the antenna. I did sand and buff the hell out of it so it would look decent.
Old Aug 1, 2016 | 01:44 PM
WP50's Avatar
WP50
Thank You
Very nice job Sir
WP
Rockrivr1
2014-2024 Touring Models
14
Oct 17, 2025 04:32 AM
torchmaster
Mar 23, 2017 07:11 PM
Recon
Jul 28, 2010 01:56 PM
Brick0044
May 12, 2010 08:43 PM
Bushy
Jan 17, 2006 12:12 AM
