Which brake light modulator to use ?
Old Aug 5, 2016 | 04:13 PM
Cozz's Avatar
Cozz
Default Which brake light modulator to use ?
I have the HD run/turn/ brake module in place, love it , works great. Is there a plug and play brake light modulator that works with it ?
Old Aug 5, 2016 | 09:38 PM
Mobeus102's Avatar
Mobeus102
Default Answer
I think your gonna need a kuryakyn rtb or custom dynamic,s rtb module or get a bal-1 brakelight with many flash pattern,s if you want to get someone's attention bal-1 is best .
Old Aug 5, 2016 | 09:44 PM
OkieBill's Avatar
OkieBill
Exactly - BAL-1 is very good. It also works well with the "run/brake/turn" module from the MOCO. Plus it looks awesome. At least to me anyway
Old Aug 5, 2016 | 09:45 PM
QC's Avatar
QC
First call I'd make would be to the people at Custom Dynamics.
Old Aug 5, 2016 | 10:48 PM
mkguitar's Avatar
mkguitar
I love my BAL-1R
I bought it used on the forums classifieds for about 1/2.
fair deal, works great
not only are the flash patterns adjustable, but just the run and brake functions can be made MUCH brighter.
mine is set for a couple of quick flashes, then steady on
this is the pattern a riding Pal used, and I found it worked well to catch attention with out being obnoxious
TOO bright or TOO much flashing can cause target fixation in drivers- there have been studies showing an increase in collisions with stopped cop cars since bright flashing leds have come more into use...I know that sometimes I can;t see past or around a stopped emergency vehicle with more lights than Iron Maiden
Mike
Old Aug 5, 2016 | 11:38 PM
bklynbob's Avatar
bklynbob
Default Sound Off Signal
Install another light. Ghost multi mount brake/tail light with built in 5 pulse flasher. Small and bright $95.
Old Aug 6, 2016 | 07:52 AM
santajim's Avatar
santajim
Custom Dynamics
Old Aug 6, 2016 | 01:09 PM
Cozz's Avatar
Cozz
From what I've been reading, the CD smart triple play does it all. Run turn brake and many strobe patterns. I was hoping to not have to start over. I just GOT this aux. brake light module. There has to be one that will work with it.
Old Aug 6, 2016 | 01:31 PM
boro's Avatar
boro
Consult your local laws. Consistent flashing is illegal in TN. The Kury rtb is ok because it only flashes a couple of times, then is solid.
Disregard, if this is not pertinent.
Old Aug 6, 2016 | 01:34 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
the previous owner of my 13 put the Kury unit in with LED lighting. no way on heck anyone in back of me isn't going to notice I am braking.
