K and N and other ????????????
Old May 22, 2007 | 11:01 PM
relli's Avatar
relli
Default K and N and other ????????????
hey guys a few ???????????
is a KandN filter really all its said to be??? if i install one will i have any adj's to make?
are those hose clamps on the exh heat shields and can they be turned so you dont see em?
Old May 22, 2007 | 11:05 PM
btefft's Avatar
btefft
Default RE: K and N and other ????????????
I have a K & N, like it. Tech had to do a download to go with it.
Hack
Old May 22, 2007 | 11:41 PM
cavedog's Avatar
cavedog
Saw an interesting demo in an auto parts store. Had a display with 2 small 5 inch fans sucking air into a tube with a ping pong ball in it. With the K&N filter the air sucked through the filter would blow the ball to the top of the tube. Change it out and put in a paper filter and the ball would fall to the bottom. Put my hand over the K&N filter and you could feel the air being sucked in. Definately more air moving with the K&N. Maybe just a gimmick but I thought it was interesting.
Old May 22, 2007 | 11:43 PM
hogdad's Avatar
hogdad
By itself its better than a stocker but nothing to write home about. Combined with other mods it always has proven itself a valuable puzzle piece when you get the write formula.
Old May 23, 2007 | 02:20 AM
Rodent's Avatar
Rodent
K & N Filter # HD-0800 $69.95.
The last filter you will have to buy.
Worth $70 ??????????????????????????????
Old May 23, 2007 | 02:50 AM
gdbro4's Avatar
gdbro4
Who makes the filter used in the Harley Stage I air cleaners??
Old May 23, 2007 | 03:30 AM
Cryptoboy's Avatar
Cryptoboy
ORIGINAL: gdbro4
Some Korean in a sweatshop.
The S/E air filter is NOT a K&N!!!! It's paper for one thing! If you sneeze on it, it will dissolve.....
Old May 23, 2007 | 03:58 AM
gdbro4's Avatar
gdbro4
Does anyone know the K&N filter part number to replace my SE Stage I filter? Thanks.
Old May 23, 2007 | 08:31 AM
relli's Avatar
relli
but do i just install one or does it require adj to the compas one person said
Old May 23, 2007 | 08:57 AM
smknflms's Avatar
smknflms
..K & N Filter # HD-0800 at local Auto Zone about $42..
Later
