V-logo indicators
Old May 23, 2007 | 10:57 AM
2007rkjb's Avatar
2007rkjb
Default V-logo indicators
Does anyone have the V-logo turn signal indicators ( 91578-00 ) mounted on
their Road King ??
Like 'em ??
While I have it apart swapping bars, I thought this might be a good addition.
Thanks,
Jake
Old May 23, 2007 | 02:47 PM
Horsepucky's Avatar
Horsepucky
6th Gear
Default RE: V-logo indicators
Yeah, I have them and I like them. I put them on to get easier signal indication without having to look down to the console. The only negative thing was that they will interfere with a tach mount depending on which bracket you use. Also, it's a good idea to use a 3 pin male/female disconnect for the wiring for ease of later removal of the shroud.
Old May 23, 2007 | 03:53 PM
2007rkjb's Avatar
2007rkjb
Thanks,
That's exactly why I want it.
I would rather have the indicator lights up front in my field of vision.
I have the combo speedo/tach so it should be no problem.
Are they easy to see in the daytime ??
Jake
Old May 23, 2007 | 06:06 PM
Wags1's Avatar
Wags1
I was lookin at those too. Are they easy to install? How do you run the wires, do you need to drill a hole in the chrome handlebar mount cover?
Old May 23, 2007 | 10:55 PM
Potato_Potato's Avatar
Potato_Potato
One of the best and cheapest mods I've done. Yes you have to drill a small hole in the cover. They are very visible in all lighting conditions. I had a little trouble with the wiring only because I am a little color blind. I think the colors were purple & lavender. I had no idea. I even went out and bought one of those Reveal light bulbs that are supposed to show the true colors - still could not tell the differance. Then I noticed that the plugs have very small numbers for each wire so I get my magnifing glass.... that worked. I am a little **** so every time I hit the turn signals I have to look to see if they came on & then, of course, I have to look to see if they went off.
Old May 24, 2007 | 12:33 AM
Horsepucky's Avatar
Horsepucky
6th Gear
Yep, decent visibility in the daylight. A drill templateis supplied with the kit and 3 holes need to be drilled in the handlebar cover/shroud (1 for the wiring, 2 for the mounting screws). The wiring connection is fairly basicand is all contained within the headlight nacelle.
Old May 24, 2007 | 02:23 AM
Whiskers's Avatar
Whiskers
One of the nicestadd-on features for yourRKC! I really like mine...they're easy to see in the daylight and I don't have to drop my head to search for the signal indicator on the console.
I highlyrecommend them to anyone who has a Road king.[sm=smiley20.gif][sm=smiley20.gif][sm=smiley20.gif]
Old May 24, 2007 | 09:57 AM
2007rkjb's Avatar
2007rkjb
Thanks for all the feedback.
Looks like it's a good deal.
Jake
Desertram800
Aug 11, 2014 12:56 PM
mrr4312
Jan 13, 2013 02:26 PM
jimglassford
Feb 5, 2012 06:06 PM
Danzyg1
Oct 13, 2010 05:40 PM
al704
Mar 23, 2008 02:31 PM
