made neck adjustment, still wobble
Old Aug 24, 2016 | 07:52 AM
kidn1980's Avatar
kidn1980
Question made neck adjustment, still wobble
to start a little short story 06 rk air ride in front and back, replaced stock rim with 23 and installed the arlen ness 7 and 7 triple trees. I had a wobble at high speeds so I took the info given on here to help me and made the adjustment reconnected everything and seem to still have wobble. I do have a batwing on front as well. I know there is something I could do to make it stop, and before everyone says "yea return it to stock". I want to exhaust everything. please help and thank you
Old Aug 24, 2016 | 09:47 AM
SG-Jay's Avatar
SG-Jay
Have you checked swing arm and rear wheel bearings? You didn't say you had it before the mods, so I assume you did not, but it's worth a shot to check. Front wheel bearings should be new with a new front wheel.
Old Aug 24, 2016 | 09:52 AM
Keithhu's Avatar
Keithhu
Also check front motor mount. They have a habit of shearing laterally, like a sliced bagel, and causing wobble issues. A raked steering head and large wheel can expose stability/wobble problems related to the front motor mount
Old Aug 24, 2016 | 11:16 AM
mkguitar's Avatar
mkguitar
I'd find a pro with experience with custom mods like yours- in general a raked front end should be MORE stable at speed..
pay for someone's experience
Mike
Old Aug 24, 2016 | 11:38 AM
wscott's Avatar
wscott
1st is what do you mean by wobble at higher speeds?
70mph or 85-90mph,or what?
But in general heres a few things that COLLECTIVELY TOGETHER can cause wobble issues on a 10 yr old bike like you have.
* worn & or out of adjustment front steering head bearings. ( Maybe not in your case because you just adjusted / tightened them.)
Scott
* 1/2 worn out tire/s can add to wobble issues.
* worn rear swing arm bushings.
* weak / worn rear shocks & front fork springs making for a mushy stock suspension.
* Is front faring & mount properly aligned / straight?
* is front wheel properly aligned / straight in front forks? (same goes for front to rear tire aln too)
* worm motor mounts if motor has rubber mounts.
Old Aug 24, 2016 | 11:48 AM
bagman1's Avatar
bagman1
As stated above, I might also add especially at this point to eliminate any simple overlooked things. Try adding ride on tire balancer/sealant to the tire. This will take up any imbalances especially if the weighted balance is not correct (actually you can toss the weights with this stuff).
Old Aug 24, 2016 | 01:26 PM
kidn1980's Avatar
kidn1980
first off thank you for responding
sg-jay: no I have not checked rear wheel bearing but have a new tire and balanced, and yes new front new everything
kiethhu: have not checked front motor mount but will do that as well.
mkguitar: I think that might be my next step
wsscott: yes about 70mph the handlebars started to shake/wobble
*new head bearing with triple trees
*both rear and front are new balanced tires
*will look at rear swing arm bushing
*new air ride installed in front and rear along with shocks
*front fairing looks straight and aligned
*front wheel is spaced correctly to my knowledge
*will look at motor mounts as well
bagman: its not weighted balanced, it has those beads
Old Aug 24, 2016 | 01:58 PM
bagga's Avatar
bagga
loose rear spokes... if you have them.
Old Aug 25, 2016 | 12:55 PM
kidn1980's Avatar
kidn1980
I also noticed it at lower speeds as well......should I look at anything different?
bagga: I was asking someone today and that's exactly what they told me then I come on here and read what you wrote....going to check them out as well thank you.....
Old Aug 25, 2016 | 02:55 PM
wscott's Avatar
wscott
AH,just assumed he was running AL wheels & forgot about rec he chk spokes if his bike has them so tks for mentioning it.
Scott
