Please help!
Old Aug 24, 2016 | 01:25 PM
Fredsharley's Avatar
Fredsharley
Default Please help!
I have an 08 Electra Glide classic and for the past couple weeks I have been smelling a weird burning smell. Today , when i went to start the bike i noticed the hi-beam indicator was on. I then found out the headlights don't work on high or low beam. Could that be the burning smell? I have not checked anything yet. Thx for your help.
Old Aug 24, 2016 | 01:45 PM
mkguitar's Avatar
mkguitar
probably burned the plug/wiring on teh back of the headlight.
usually easiest to remove the outer fairing, but that requires unplugging headlight- if your plug is melted on that'll make tough, so remove the headlight and bucket from teh front
replacement plug at any auto parts store- get a high temp replacement and crimp connect to bike wirings ( do not solder).
if you added a high wattage bulb, toss it and get a silverstar
Mike
Old Aug 24, 2016 | 03:25 PM
Fredsharley
Thx Mike, you were right. The plug was melted! I don't know how. I have a regular lightbulb. Will it happen again?
Old Aug 24, 2016 | 03:41 PM
mkguitar's Avatar
mkguitar
it will get hot if there is corrosion in there.
so you have a new plug...
on your bulb- without touching the glass, clean the metal blade/tangs- use a rubber eraser or an light file or sandpaper/emery board like stolen from your wife.
put a little dieelectric grease on the tangs and plug it in.
at least you know how easy the fix is and if you smell smoke again...
Mike
Old Aug 24, 2016 | 04:03 PM
bzb123's Avatar
bzb123
Perfect time to upgrade to an LED headlight.
A lot less current draw, very little chance of it happening with an LED.
Old Aug 24, 2016 | 04:09 PM
jammerx's Avatar
jammerx
if you keep your halogen or upgrade to a higher wattage...
http://www.easternbeaver.com/Main/Wi...s/h4_kits.html
hotwheels57
Dec 1, 2018 02:05 PM
Holloway2146
Electrical/Lighting/Alarm
Aug 26, 2017 01:48 AM
misfitJason
Feb 6, 2013 01:01 PM
discodago
May 8, 2008 07:57 PM
TexasRanger
Oct 19, 2007 08:30 PM
