J&M replacement speakers
07street
I ordered a set of your speakers for my Street Glide last month and they were shipped and recieved quickly. Install was straight forward and they make a nice improvement over stock speakers for anyone that is still considering a pair. Thanks for the info that lead me to purchasing your speakers, and glad to see you are now a full sponsoring member of this community. Cudo's to you and all the info you have provided.
Graeme
My problem is; I already have XM direct in the faring and it's getting a little crowded in there.
But there is no doubt I will have to go with a class T digital amp. Light weight and less power which means lower heat.
I really would like to hear from someone that has been running one of these type amps.
Strongly considering anamp.The research I've done on an amp suggests there are two companies producing good ones designed for low heat/low amp load. Titan ($400) available through biketronics and hawg wired ($600) available through hawg wired.Apparently the best way to get high output and low amperage is to use a class T type amp which allows it to be also very small (but expensive). Both fit under the fairing. With a Sony player and two fairing speakers no matter whose speaker you go with the sound is less than desirable for me.............
the J&M speakers have been designed to not only give you the best sound and highest volumes with the stock Harley radio ,,, but with aftermarket radios and additional amplifiers as well ,,,,,,
rated at 140 watts max power, they are quality speakers that will take just about anything you can throw at them ,,,,,
JMJOHN ,,,, john@jmcorp.com ,,,,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Well my JM'S showed up at my door today. I can't install them on my bike yet, still waiting for an HD harness for XM. So I looked at them for awhile then thought Why Not... They make somewhat heavy headphones with some duct tape and coat hangers, but the sound is aweome. [:-]
