2008 FLHTCU Ring Gear Teeth
Old Sep 26, 2016 | 07:08 PM
MichiganDave's Avatar
MichiganDave
Default 2008 FLHTCU Ring Gear Teeth
Need some opinions here from those of you who have had this issue.
Have had the hot start grinding issue on my 2008 Ultra for quite some time which seemed to be progressively getting worse the last few weeks.
When I dropped the primary fluid it looked like a tooth for sure on the magnet but went ahead and pulled the primary cover to see the extent of the damage. Only one tooth was broken off the ring gear.
I've done a lot of reading on the issue and I'm curious what exactly caused this tooth to bust off. As for the repair whats the best way to go? New ring gear, new clutch basket or should I just go with a whole new clutch assembly? Is it safe to assume that I also need to replace the starter clutch and upgrade to the SE compensator?
Old Sep 26, 2016 | 10:33 PM
Eunoterpsia's Avatar
Eunoterpsia
Well, a starter's pinion gear will cost you about 30 and I know a clutch assy would set you back damn near 6 benjamins.
I'm confused as to the conversation about an SE Compensator... I mean... if money is no issue and you are concerned that a weak or failing compensator is contributing to the failure or back lash on the starters pinion gear... thus breaking a tooth... then why not.
if nothing is wrong with the clutch... I'd say the shearing of the tooth had more to do with the compensator.
Once I took a look at the non SE (for our year bikes) compensator spring pack... I installed the SE Comp.
Old Sep 27, 2016 | 09:35 AM
X Iron Butt's Avatar
X Iron Butt
When my starter clutch went it made the grinding noise and the bang. The grinding is chatter of rollers in the sprag clutch slipping on it's shaft and the bang is in the wound up tight compensator unloading when the clutch finally looses all of its grip. I would replace the starter clutch and see how it goes. I would not be completely comfortable with missing one tooth but it might be worth a try. Look at the teeth on both sides of the missing tooth for cracks and damage.
The ring gear used to be replaceable but HD doesn't offer it outside of the $500 assy. from what I can see.
shovhd
EVO
16
Dec 19, 2018 03:50 PM
Ted Jones
Nov 3, 2017 06:47 AM
soft 02
Sep 29, 2011 01:06 AM
OlGrampy
Ironhead
May 1, 2011 09:34 PM
Spitshine
Ironhead
Apr 24, 2007 09:54 AM
