Moved my horn to the "firewall" between the battery compartment and the rear cylinder. There are holes already in that steel plate where you can insert 1/4" bolts to hold a horn or two...I have two Fiamm horns mounted in that area so the horns are not visible and with the high and low tone horn it sounds like a car horn.
Joe, are your horns mounted on the inside or outside of the "firewall"? Inside meaning towards the battery and out of sight. Got a picture?
Cruising on the slab.....I feel something hitting my leg. I look down my horn is hanging by just one of the wires. Bracket snapped right in half.
I do have Wards fans and a after market horn cover. The cover seems about the same weight of the OEM one.
Nothing a little time with the TIG machine won't fix (as far as the bracket goes anyway). I welded up a couple on my 01 that did the same thing, good as new.
+1 starting to feel the cramps and bloating. wards fan occasionally taps the front jug...ting ting. never did that before.
YUP...thats what I was hearing before the rubber mount broke.......put a few washers in to move the fans outboard.......made the rubber wear out faster......
I mounted 2 additional horns on my bike off of the front fuel tank mounts, tapped into the stock horn. Faced them forward and slightly down so as to not collect water. I went with 2 FIAMM Horns, a low note and a high note, from Amazon.
Personally, I am not a big fan of the stock horn location, or the direction. If my mount there ever breaks, it will just be gone, no huge loss.
