Smoked Tail Light Question
Old Oct 6, 2016 | 08:23 AM
bulldog82098's Avatar
bulldog82098
Default Smoked Tail Light Question
Dennis Kirk has smoked tail light lens' for my 16" Road King:
https://www.denniskirk.com/drag-spec...prd/215489.sku
I v\believe this is the lens I need with the bottom tag window?
Can I then use this bulb?
https://www.denniskirk.com/drag-spec....prd/22419.sku
Old Oct 6, 2016 | 09:23 AM
whocares's Avatar
whocares
Custom dynamics led tailight. That bulb you're talking about is useless.
Old Oct 6, 2016 | 10:08 AM
bulldog82098
Yes but your talking over $150.
The original tail light uses a halogen bulb
just like the one listed. Why wouldn't the smoked
light be the same??
Old Oct 6, 2016 | 10:43 AM
heavypic's Avatar
heavypic
OP - Thanks for the info. I've been looking for a lay-down, smoke tail-light for my '14 RK. If that Drag Specialties halogen bulb is not bright enough, I'm guessing you can probably find another red halogen with brighter intensity. Let us know how it works out.
Old Oct 6, 2016 | 11:10 AM
Whodey's Avatar
Whodey
I am working on my rear lighting as well. I am removing the stock turn and inserting saddlebag support turn signals and going with a R-B-T module. I was going to go with the smoke brake also but red LED is much cheaper. Is there a benefit to the smoke or really just cosmetic?
Old Oct 6, 2016 | 11:15 AM
bulldog82098
Cosmetic, the reason smoked is more expensive is just a scam. Maybe you can buy a red LED and replace it with the smoked lens?
Old Oct 6, 2016 | 11:22 AM
Whodey's Avatar
Whodey
From everything I am finding the rear break does not have a plug and play type LED bulb. Need the LED conversion kits.
Old Oct 6, 2016 | 11:24 AM
bulldog82098
Cheapest one I can find so far....
https://www.denniskirk.com/drag-spec...prd/215354.sku
Old Oct 6, 2016 | 12:21 PM
bikerlaw's Avatar
bikerlaw
I am running the setup you are talking about. I run a simple smoked replacement lens, and a cheap 3157 LED replacement blade style bulb. It's bright as heck, and MUCH cheaper than the options I have seen. Second pic is brake lights ON.
Edit: My turn signals are standard red 1156 bulbs and I use the run/turn/brake module.
Attached Thumbnails Smoked Tail Light Question-bulb.jpg   Smoked Tail Light Question-bulb2.jpg
Old Oct 6, 2016 | 01:48 PM
Just Me's Avatar
Just Me
Smoked lense's on ALL vehicles should be outlawed!
