I only ask because my fairly pricey Zumo died and I like having one on the motorcycle for several reasons. My fault I guess, I never read the ZUMO owners manual which I now know says:
Your zūmo contains sensitive electronic components that can be permanently damaged if exposed to excessive shock or vibration outside normal motorcycle use
This is not possible on a Harley Davidson because when it idles, or is at low R's the GPS unit shakes profusely, far beyond normal motorcycle use.
So I guess maps are probably the best answer? Or, has anyone figured out a way to mount a GPS where it doesn't shake and bake?
That sound like a CYA disclaimer from Garmin. I've had Zumos 450 and 550s on 4 different Harleys, an FXDF, FXDWG, and 2 different FLSTCs...Currently have a 590 on a Heritage, and other than the Li-ion battery in the 590 went bad after only 2 years, not a problem-except the replacement battery costs $50...
Reason: added model numbers
Load of hooey.
I have run the same TomTom on a Dyna Low Rider, Fat Boy and my Road King. $89 on Amazon, with the $15 mount. Been working for over five years. You can clearly see my TomTom in my sig pic. Any unit will work as well on a bike as it does a car. .... till it rains. If that's a concern, carry Ziploc baggies or spring for a waterproof model. But I have never had one vibrate apart..... yet.
...has anyone figured out a way to mount a GPS where it doesn't shake and bake?...
My gps is mounted in a clear front cell phone carrier that I have clipped on the my fairing packet bag thingy- it is just below line of sight to the road.
it also works as a phone and I get email.
i see no advantage to a stand alone "gps" unit- anything it can do, my phone can do too.
I've used a TomTom for many years, not long after the bike version first came out. If your using a car one, that may not be as robust, but a bike-specific one is designed for - working on bikes! Mine work fine on all three of my V-twins, Glide, Sporty and Firebolt and have taken us all around Europe. Perhaps your roads are worst?!
5" Garmin Nuvi, can't remember model, for over 50K mounted on handlebar. I just put a ziplok over it when caught in the rain... For the $80 its disposable if it ever does die..
