Floating Rotors - High Pitched Whine
Old May 28, 2007 | 06:04 PM
jdag's Avatar
jdag
Default Floating Rotors - High Pitched Whine
I recently had floating rotors installed on the front of my 2006 Street Glide. It has alleviated that "harmonic hum" many of us have experienced in the past.
However, I am not getting a high pitched whine. The whine is most noticable during slow speed turns.
The slightest tap of the front brake lever will make the whine stop. But as soon as I release the front brake, the whine returns. I am fairly sure that the noise is constant, but only being noticed at slow speeds because of engine and wind noise.
Could it be a mis-alignment of the calipers? A need for new brake pads?
Thanks, John
Old May 28, 2007 | 06:17 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: Floating Rotors - High Pitched Whine
I notice my floaters must be slightly thicker than the stock rotors as they have a good bit of drag. They haven't turned blue, so, I haven't worried about it. My exhaust is the only thing I hear when I'm going other than the gear drive cam.
Old Jul 16, 2007 | 05:33 PM
Greyplm's Avatar
Greyplm
3rd Gear
Jay - I have a 1200C, 2007 Sportster and I am having a hard time getting information on my problem. Basically when I brake (both rear and front), I get that harmonic hum you were referring to but couldnt find any posts or info on it...any ideas? thanks so much for the help.
Old Jul 16, 2007 | 05:38 PM
Kahuna's Avatar
Kahuna
Did you change to new brake pads when you had your floating rotors installed? This is a must do! If your new rotors are chrome, you may not be able to use the stock HD brake pads in the future. There are brake pads available for the floating rotors. Remember, also, that you may never get an exact alignment between the calipers and the rotors. Unless you use some shims on the calipers. Even then, you may still hear some noise.
ORIGINAL: jdag
Thanks, John
Old Jul 16, 2007 | 08:38 PM
gilbos440rt's Avatar
gilbos440rt
Most I've seen go away in a few hundred miles.
Stalkdaddy
Apr 4, 2015 08:59 AM
SE11
Aug 31, 2013 12:00 PM
JosephGarcia
Nov 15, 2007 10:46 PM
lowleveldriver
Aug 28, 2006 11:07 AM
flying12
Apr 9, 2006 02:09 PM
