Remove front ABS for Single Caliper?
Old Dec 11, 2016 | 10:58 AM
Fine09's Avatar
Fine09
Default Remove front ABS for Single Caliper?
I'm in the process of making the swap to a 21" front wheel with one caliper and I need some advice on the brake line.
For those of you that have switched to a larger front wheel and only one caliper, did you a) eliminate your front connection to the ABS module and only run a single line directly from the main reservoir on your handlebar, or b) did you find a single line that will run from the ABS module to the front caliper?
Appreciate any advice. Thanks.
Shadowray
Touring Parts
Oct 19, 2018 08:08 PM
Fine09
Mar 2, 2017 10:03 PM
Shadowray
2014-2024 Touring Models
Apr 18, 2016 06:38 AM
BadPiggy
Jun 6, 2012 09:38 AM
Jenkie
Oct 8, 2011 09:42 AM
