Front Brake Line for Single ABS Caliper
Old Feb 27, 2017 | 10:14 PM
Fine09's Avatar
Fine09
Default Front Brake Line for Single ABS Caliper
When I moved to a 21" wheel on the front of my 09 RK, I went to a single left-side caliper. I currently have it set up as non-ABS straight from the master cylinder. However, I want to re-install the ABS line from the ABS module to the single front caliper. I can't find a brake line that runs all the way from the module under the seat to the front caliper. The stock one splits into two lines for the front. I only want one unbroken line that doesn't have to be mounted under the headlight housing. Can anyone point me in the right direction? Thanks.
Old Mar 2, 2017 | 10:03 PM
Fine09's Avatar
Fine09
Just reviving this thread to see if there is any input.
Fine09
Jun 14, 2022 06:03 AM
tech7734
Apr 22, 2017 10:45 PM
Fine09
Dec 11, 2016 10:58 AM
marvo75
May 8, 2013 08:18 PM
BadPiggy
Jun 6, 2012 09:38 AM
