Knock in front end
Old Dec 23, 2016 | 10:32 AM
pt4u2nv's Avatar
pt4u2nv
Default Knock in front end
The last couple of times on my bike it seems the front forks are making a knocking noise when I hit bumps. It seems to be getting worse as time goes on. The bars are solid when running at high speed and taking hands off of grips, no vibrations, seems normal until I hit a bump. Checked everything I could get to and nothing is loose. Thinking maybe head bearing loose but it is smooth as silk until I hit a bump. Any ideas ?
Prob will take it to dealer and have them look at it as it is still under warranty.
Note: I do have almost 50,000 miles on it. 2012 Limited lowered front and rear.
Old Dec 23, 2016 | 10:37 AM
Tracker1's Avatar
Tracker1
I have the same thing, even after tightening the neck bearing. I'll be watching this thread.
Old Dec 23, 2016 | 10:39 AM
larsfum's Avatar
larsfum
Make sure that the fall away is correct, and lube the neck bearing,
Old Dec 23, 2016 | 12:05 PM
mkguitar's Avatar
mkguitar
I had a Pal with BIG front end problems- it just came out of nowhere and light bangs and clack on bumps and starts and stops.
He could hear it but not feel it
low on gas, it was the fuel float.
Mike
Old Dec 23, 2016 | 12:07 PM
Ruggs59's Avatar
Ruggs59
Have you ever changed the fork oil in that 50 thousand miles?
Old Dec 23, 2016 | 01:06 PM
pt4u2nv's Avatar
pt4u2nv
Full tank of gas.
Fall away is as good as it should be.
Fork Oil changed twice now with the Heavy weight oil both times.
Hopefully dealer will find something. Kinda concerning not knowing if something is coming apart internally that could fail. Prob will not ride until I get an answer as to what it is.
Old Dec 23, 2016 | 02:07 PM
Wilee's Avatar
Wilee
Engine stabilizer link.
Been there, changed it, clunk gone.
Plastic encased heim joints wear out quickly.
2013 FLHTK, worn out around 30,000 miles.
Old Dec 23, 2016 | 02:17 PM
81rat's Avatar
81rat
Check fork oil for correct amount and weight
Old Dec 23, 2016 | 02:57 PM
pt4u2nv's Avatar
pt4u2nv
Put the exact amount back in that was drained out. Went to heavier weight oil ( Screaming Eagle Fork Oil Heavy Weight ) , I think it was labeled, which worked much better than the stock weight the last 2 changes. That was about 8,000 miles ago
Old Dec 23, 2016 | 02:59 PM
pt4u2nv's Avatar
pt4u2nv
I will have to check that out . Certainly sounds like that could cause the noise. Thanks
