Knock in front end
Old Dec 23, 2016 | 04:16 PM
Wilee's Avatar
Wilee
Pull it off, if you can easily spin the b@lls, there's your problem. That little movement makes it clunk and resonates through the frame to the bars. Took me a while to figure out. Thought for sure it was my steering neck bearings.
Old Dec 24, 2016 | 12:15 PM
Bowhunter61's Avatar
Bowhunter61
If it ain't the stabilizer then check to make sure the fork tubes are tight in the triple tree
Mine had come loose on the lower tree on one side , not enough to effect handling but to make the kind of clunk you are describing
Old Dec 25, 2016 | 10:08 AM
sleighcrane's Avatar
sleighcrane
I've got the same thing going on with my bike. I tightened the neck bearing and the fall away is great no more shimmy without hands on bars but now a clunking sound as I hit bumps. Say I come out the driveway to the curb and a clunk as I transition from curb to street and then good. I have progressive springs and SE fork oil. Would love to cure it.
Old Dec 25, 2016 | 10:44 AM
joe.1955's Avatar
joe.1955
Check to make sure your fuel tank mounting bolts are tight. If they are even slightly loose the tank can raise over a bump and come down on the backbone of the frame causing a clunking noise.
Old Dec 25, 2016 | 11:47 AM
bad tappets's Avatar
bad tappets
Front brake calipers bolts? Rotor bolts? Head light loose? Good suggestions by others here too.
A rubber mallet can be useful to diagnose things like this. Start at the front axle bolt and give a light wack with the mallet. Listen for anything that rattles, bangs, bumps, etc.. Work your way along methodically.
Old Dec 25, 2016 | 03:40 PM
billib1954's Avatar
billib1954
Loose tank mounting bolts....................
Mine s a Dyna, but it was this.
Old Dec 25, 2016 | 03:52 PM
81rat's Avatar
81rat
The rubber mallet sounds cool -- thanks bad tappets
Old Dec 25, 2016 | 07:55 PM
bdtaylor1979's Avatar
bdtaylor1979
Recently had a similar situation and it ended up being loose bolts holding the front fender on.
EricD10563
Jun 25, 2014 06:25 PM
Port Dawg
Aug 19, 2011 12:32 PM
russell6hp
Jul 13, 2010 03:52 AM
Hog Yild
Jul 10, 2009 01:42 PM
Hounds2
Mar 30, 2009 10:51 AM
