Adjusting progressive shocks
Old Dec 30, 2016 | 12:28 PM
mayhem912's Avatar
mayhem912
Default Adjusting progressive shocks
Good afternoon all. I recently installed a pair of progressive 444-4020b. The ride is stiff, how do I adjust the shocks for a softer ride? They say hand adjust.
Thanks in advance!
Old Dec 30, 2016 | 02:04 PM
EG-2006's Avatar
EG-2006
Instructions
Old Dec 30, 2016 | 04:08 PM
nevada72's Avatar
nevada72
How much do you weigh?
Old Dec 30, 2016 | 04:10 PM
EasternSP's Avatar
EasternSP
Just like unscrewing a big bottle cap. Both hands around the top part of the shock and twist.
Old Dec 30, 2016 | 06:34 PM
smitty901's Avatar
smitty901
The progressives will some times get stuck. Then you use a band type strap to get them lose so you can turn them. My 944's did that. sorry to say the 944's ended up in the bad Idea box.
Old Dec 30, 2016 | 06:52 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Get yourself a rubber strap wrench if you can't turn the adjuster by hand. That's what I use on my 944's. I've also put a reference line on the adjuster and barrel to help with adjustments.
Old Dec 30, 2016 | 09:09 PM
mayhem912's Avatar
mayhem912
325 pounds
Old Dec 30, 2016 | 09:13 PM
TriGeezer's Avatar
TriGeezer
Yeah...I couldn't turn them by hand.
Old Dec 30, 2016 | 09:27 PM
nevada72's Avatar
nevada72
Originally Posted by mayhem912
325 pounds
My guess is you're bottoming out the shocks. Who told you to get that spring rate?
On compression tools - this is the one you want. You'll need it to change out the springs to the right ones for you.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
As has been mentioned, the threads can get gunked up (even when new). It's best to take them apart and clean and (dry) lube the threads. Makes it a lot easier to adjust.
Old Dec 31, 2016 | 02:13 AM
mayhem912's Avatar
mayhem912
According to their website, the 444-4020b is a heavy duty shock for 300+ pounds of rider/passenger/gear
