'05 RK question on bearings.
Old Jan 4, 2017 | 10:00 PM
giacomo56's Avatar
giacomo56
Default '05 RK question on bearings.
11 year old RK...love my bike...lately the front end feels squirley...like it's looses....trying to describe the effect is hard by words...but going at 70 mph the handle bars kind of fishtail....was told to replace the bearings in the wheels and swing arm......is that the "cure" .... also while at it replace/check the neck bearing and since the swing arm is out maybe replace the motor mounts.....
Wish I could do the work but I am not mechanically inclined.....what is the approximate costs associated with changing the wheel bearings/ neck bearing and motor mounts?
Old Jan 4, 2017 | 10:08 PM
mkguitar's Avatar
mkguitar
first is to check the tire pressure, condition etc. has the tire ever suffered an impact or been flat? balancing weights in place?
you can look up fall away test for the neck bearings- that is pretty easy to do- it takes time but not tricky, esp on a RK- make sure you disconnect the clutch cable at the lever
fork oil and seals? if the 2 legs are working differently, you'll feel it
checking the alignment of the drivetrain in the frame is easily done with 2 x 8' florescent light tubes. bike upright, one tube each side of the rear tire extending forwards- distance to front tire each side should be same
if the swingarm needs servicing that is a big job- and if your mileage is up, you'd want to replace the belt ( which itself has a labor cost 5 times the cost of the part- most of that cost is getting to and removing the swingarm)- unless you have alot alot of miles, though I doubt it
mike
Old Jan 5, 2017 | 05:47 AM
grbrown's Avatar
grbrown
Wheel bearings are well worth checking. Lift each wheel so you can turn it by hand - if it feels or sounds bad, it is! Tyres are also a cause of such problems. If the treads are worn or showing an odd wear pattern replace them. Nice new tyres can be a sublime experience!
Old Jan 5, 2017 | 06:44 AM
Architect's Avatar
Architect
I would be looking at neck bearings based on your description, the front fork sounds loose, fall away test is the way to go. Good luck.
Old Jan 5, 2017 | 12:19 PM
bigheadted's Avatar
bigheadted
I once swapped windshields and it caused some weird handling at speed
Old Jan 5, 2017 | 07:50 PM
Keithhu's Avatar
Keithhu
when was the last time you checked your spokes?
Make sure they are tight and trued.
Service manual describes how to make sure they're true.
Old Jan 5, 2017 | 08:29 PM
giacomo56's Avatar
giacomo56
No spokes...have wagon wheels/rims....rims where just balanced....
Thank you...though.
Old Jan 5, 2017 | 08:52 PM
Keithhu's Avatar
Keithhu
Thank you...though.
Well, I tried. Also, have you examined your front motor mount?
They have a habit of shearing in half like a sliced bagel.
As far as cost, I think the replacement part is something like $80, cant take you more than 30 mins to replace. Latest replacement part has upgraded material.
$63 at Board Tracker HD. http://www.boardtrackerharleyonline....gine-16207-79d
Old Jan 6, 2017 | 05:07 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Had you done any work on the bike prior to this swaying wiggling phenomena arising? If so, start there.
If this swaying wiggling phenomena started faintly and become more pronounced, I'd strongly suspect suspect the tires. Tires can become quite unpleasant as they age.
Widow_Maker
Sep 11, 2012 03:38 PM
Chopperbob
EVO
Jul 31, 2012 03:37 AM
kjelders
Jul 9, 2012 10:56 AM
the_ogre25
EVO
30
Nov 23, 2009 12:20 PM
Lpye
Apr 18, 2005 01:31 AM
