Control wire extension?
Old Jan 5, 2017 | 02:33 PM
Buckloggers's Avatar
Buckloggers
Stage IV
Default Control wire extension?
hello everyone! I just bought the LA choppers 14" ape hangers. I purchased longer clutch cable, brake lines, and a plug and play throttle extension. Everything is in the mail on the way, and my bike is already tore apart ready for the new set. My question is, do I need to purchase a wireing extension for my controls? Turn signal, lights, radio etc. I can't find anywhere saying I need to, but I may have over looked it. Thanks!
Old Jan 5, 2017 | 02:37 PM
Cygnusx51's Avatar
Cygnusx51
Not sure but if you have to extend the cables and brake lines, most likely you'll need wiring extensions as well. I've used NAMZ before and they're color coded so it's easy to hook them up. You might as well wait till you get the bars in to figure out how much extra you'll need.
Old Jan 5, 2017 | 02:57 PM
Buckloggers
Stage IV
okay thabks! Just impatient is all haha
Old Jan 5, 2017 | 03:33 PM
Helomech74's Avatar
Helomech74
I used these when I did my bars: http://www.namzcustomcycleproducts.c...-baggers-only/
Plug and play replacement for the stock harnesses.
Old Jan 8, 2017 | 05:48 PM
Scarz's Avatar
Scarz
Today I swapped out the OEM bars on my Road King for Wild One 517s. Because I decided to run the control wires inside the bar, I had to stop to order wire extensions. I ordered 8" extensions from NAMZ. Now if I decide later to go to apes, I should have plenty slack to get it done. There was a lot of extra length under the nacelle for the throttle so I didn't need a throttle extension.
Spur56
Aug 25, 2016 02:14 AM
Amarano25
Jul 10, 2016 09:02 AM
jkeeton81
Mar 11, 2016 07:54 PM
Cpiper93
Jan 28, 2016 02:12 PM
DL1986
Jun 19, 2014 09:15 AM
