Torque Wrench question
Old Jan 7, 2017 | 03:51 PM
  #31
Black_Gold's Avatar
Black_Gold
Originally Posted by skratch
I agree with you, but for a tool that I use a couple times per year, i'm good with it. if it were something that I was making a living at, yeah, it's never a bad idea to go for the good stuff.
I'm with you. I have a Craftsman 1/2 in drive and sometime ago, the ring that locks the handle striped (for lack of a better term) will not lock.
Like you, I only need a torque wrench for minor jobs. So I decided to go ahead and get the HF ones in 1/4, 3/8 and 1/2 in. I never had an in/lb wrench and used to use reducers when all I had was the 1/2 in. The way see it, I'm better off now, for $60, than I was before
Old Jan 7, 2017 | 05:36 PM
  #32
DonnieM's Avatar
DonnieM
I just bought the HF in lb torque wrench and for a limited use tool I am good with it. If I wrenched for a living and used it constantly, I would definitely invest in a good one
Old Jan 7, 2017 | 05:39 PM
  #33
sixguns's Avatar
sixguns
I like tools, so I wont purchase them at HF. Anyways, HF gets plenty of support so they dont need mine.
Old Jan 7, 2017 | 07:34 PM
  #34
Wv7o's Avatar
Wv7o
I like tools, as for torque wrenches I have 4 at home that I use:
5 -50 in.lbs 1/4 drive
50-250 in.lbs 3/8 drive
20-100 ft. bs 3/8 drive
30-250 ft.lbs 1/2 in drive
and the 1/2 inch drive 0-140 ft.lbs beam torque wrench that my grandfather gave me for my 15th birthday, does not get used anymore but I would never get rid of it.
Old Jan 8, 2017 | 06:50 AM
  #35
ohioflhs's Avatar
ohioflhs
A torque wrench is calibrated from 20 to 100% of its capacity. You can use it anywhere in that range.
Old Jan 8, 2017 | 07:01 AM
  #36
Notgrownup's Avatar
Notgrownup
Mine are cheap but I loosen them up and store them in their appropriate case in a tool box drawer.
I use them rarely but I have 3 sizes, just bought a Craftsmen digital 1/2" haven't tried it.
Old Jan 8, 2017 | 07:03 AM
  #37
13RKC's Avatar
13RKC
Of course you can use an inch pound torque wrench for foot pound applications. As long as the converted foot pound number falls within the inch pound torque wrench's range, you're good. If you have a torque wrench that goes up to 200 inch pounds, the max foot pounds you can torque with that wrench 16.6 pounds.
So, let's say you had to torque something to 15 foot pounds.....you can use your inch pound torque wrench set at 180 inch pounds and it's the same. Multiply or divide by 12, depending on what you are doing.
If you already have the torque wrench to cover what you need to do, you don't have to go out and buy another wrench. There is no "being safe" about this. It is all the same as long as you do your calculation.
Old Jan 8, 2017 | 07:09 AM
  #38
PFWiz's Avatar
PFWiz
NQA-1 (the old commercial nuclear power plant quality standard) required that all torque wrenches be sized so that the torque you were trying to achieve fell between 33% and 75% of the wrenches full range. This is the zone of maximum accuracy for any given wrench.
I know this because I was a QC/QA inspector in nuke plants for about 12 years.
Old Jan 8, 2017 | 07:11 AM
  #39
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by rscott
Harbor Freight sells quality torque wrenches very reasonalbly priced.
I`m going to disagree here...
Harbor Freight sells cheap Chinese junk.
Old Jan 8, 2017 | 07:14 AM
  #40
ohioflhs's Avatar
ohioflhs
That may well be but I am a metrologist for the nuke plants and they are calibrated to the same accuracy from 20 to 100% of their capacity. Use it anywhere in that range and the accuracy will be the same percentage.
