New Tires/Ride On
Old Jan 16, 2017 | 03:55 PM
00copglide's Avatar
00copglide
Default New Tires/Ride On
So.. I'm going to put new tires on my ride over the winter.... 2000 flhtpi... I have read a lot of good info about the Ride On product and was considering trying it...my question is do u put that product in thru the valve stem like fix a flat..or before the tire is mounted? Also does it have to be ridden right away to distribute the stuff? Winter here in Ma. so not going to be riding in the immediate future...
Thanks
Old Jan 16, 2017 | 04:09 PM
81rat's Avatar
81rat
In the valve stem , they give you a piece of hose and instructions for tire size and amount
Do not worry about it setting - it will every time you park settle to the bottom -- that is correct and before you get a few mph it will be spread out and balanced ( sweet)
It is also a puncture resistant product
I use it even in tubed tires as I install my own and don't have to pay someone to do a 1/2 *** job of balancing
Old Jan 16, 2017 | 04:10 PM
81rat's Avatar
81rat
Old Jan 16, 2017 | 04:16 PM
giacomo56's Avatar
giacomo56
I personally would wait till the springtime when you will ride...also I believe there's a temperature range that it will needs to be before you use it.....unless you have a heated garage.....never tried it but I am ready to install it, as I am in Florida......i like the fact that it can help on punctures...i was a Dyna Bead user before...will see how it does...
Good luck
Old Jan 16, 2017 | 04:24 PM
bellmnbell's Avatar
bellmnbell
Here is a link to the installation instructions. In summery, deflate the tire by removing the valve stem and squeeze the gel into the tire. The product never dries and will move within the tire to balance and seal punctures on the bottom third of the tire tread.
http://www.ride-on.com/images/storie...april-2012.pdf
00copglide's Avatar
00copglide
Thanks for the replies...will mount the tires over winter then put Ride On in the spring...One can/bottle per tire??
Old Jan 16, 2017 | 04:32 PM
bellmnbell's Avatar
bellmnbell
There is a table in the installation instructions that will define the ounces necessary, based on the tire being used.
Old Jan 16, 2017 | 04:52 PM
qtrracer's Avatar
qtrracer
And if you want to have the product balance the tire you add 25% more. There should be instructions on that as well. On my bike it ended up being 1-8oz bottle plus 2 more ounces from a second bottle for a total of 10ozs for puncture protection and balance benefits. On my rear tire it would be 14oz so that would use 1-8oz bottle plus the leftover 6ozs from the other bottle I used to complete the front tire. Total of 3 bottles needed.
Old Jan 16, 2017 | 06:32 PM
bigskyroadglide's Avatar
bigskyroadglide
im a big fan of ride on. i microwave mine before installing about 30 seconds, makes it easier to install.
i also buy the automotive bottle vs motorcycle. the automotive is 16 oz vs 8 and i generally just use one bottle for two tires. if i have some vibration i just add a little more. never figured out the differences in the motorcycle vs car versions. i ve never had a problem with either and both work.
you should do what you think is best
Old Jan 16, 2017 | 06:54 PM
blackscootersociety's Avatar
blackscootersociety
anyone dismount one that had the goo in it? messy??
