Charging system/ gauge
Old Jan 22, 2017 | 03:05 PM
jo jo jo's Avatar
jo jo jo
Question Charging system/ gauge
I have a 2013 street glide. My gauge on the dash says it is over charging when running and when it is sitting not running with just key on it reads normal volts in batt. When I have it running, as I said it says it is over charging, yet I put a gauge on it, it will say it is charging normal. Why is the gauge saying its over charging? Thanks in advance.
Old Jan 22, 2017 | 03:32 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Sounds like you may have a defective volt meter or possibly a ground issue but I'd suggest that you have your charging system checked before replacing anything.
H-D had some voltage regulator issues with the '12 touring models and I had to have the v/r replaced on my '13 CVO Ultra at about 25,000 miles.
Good luck.
Old Jan 22, 2017 | 04:41 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Active Streak: 30 Days
There was a thread similar to this a few weeks back. Turns out that there is an adjustment screw on the back side of the gauge. It may be a simply adjustment/calibration issue.
Old Jan 22, 2017 | 04:47 PM
EdwardK's Avatar
EdwardK
HD gauges notoriously suck for accuracy. Has it changed or always read this? What is the gauge actually reading? They always read high.
I think this falls into the category of a phrase which you will hear a lot regarding most any of your concerns if you are new to Harley. "Don't worry, they all do that."
If you have put a test meter on and it reads fine, then check your gauge on the dash and make a note that's normal. If it goes higher, get out you test meter again to troubleshoot and verify.
If it was really overcharging, you will get a check engine light and a stored code. Having just fried two voltage regulators and a stator....trust me. I know. ( My fault they fried. Don't worry.)
Good luck and welcome to the forum.
Old Jan 22, 2017 | 05:43 PM
mkguitar's Avatar
mkguitar
so- take a reading at the battery and compare the in dash gauge.
if you have a battery tender pigtail you can test there, saves pulling the seat.
you should never see voltages ( at the battery with a "real" voltmeter )over 14.8 - higher than that means the VR has failed and will kill your battery dead...in turn the failing battery can kill your stator. when the VR fails it may overvolt your electrical system...and may also pass AC voltage.
on analog electrical systems ( 13 and earlier, 14+ are CANBUS), the in dash gauge will usually read about a 1/2 volt low...but that is constant...on earlier models where the lighting and ignition are on the same switch ( like my evo) the gauge will read about 1.5 volts low...and dance around with the horn or the blinkers, this is due to voltage drop in the wring harness- a poor design.
so, do a test and then see what remedy if any needs doing
being where you are, if you are going to run your bike...get it hot ALL the way through to boil out any water from condensation which will form inside your cases, gas tank and exhaust.
Mike
Old Jan 22, 2017 | 06:46 PM
dodger413's Avatar
dodger413
my 13 SG has read high since day i bought it new. still reads high. nothing seems to be going wrong because of it. up in the 14-15 volt region.
Old Jan 24, 2017 | 10:54 AM
Hecklerboy's Avatar
Hecklerboy
I went through this same thing with my 2011 SG. Voltage gauge would peg out when riding. Sometimes I could sit and watch it move around while the bike was running. I checked the voltage at the battery and everything read fine. Had the shop take a look at it before my warranty expired and they couldn't find any problems. Tech told me that Harley gauges are junk and not to worry about it. I've been riding it like that for 5 years now and no problems.
Biker90
Electrical/Lighting/Alarm
Aug 25, 2017 04:53 PM
littled62
Dec 10, 2012 09:19 PM
FLHTCUI05
Sep 22, 2011 07:13 AM
Taylorized
Aug 14, 2008 09:42 PM
Steve On 3
Dec 14, 2007 11:20 AM
