Snap ring pliers
Old Jan 30, 2017 | 09:28 PM
Campy Roadie's Avatar
Campy Roadie
I have a snap on set of various sizes and angles.
Old Jan 30, 2017 | 09:34 PM
Bone Doc's Avatar
Bone Doc
Like the others, I have a pair with several interchangeable tips and converts from internal to external snap rings.
But, does anyone have a pair of pliers that prevents the snap ring from flying off into oblivion?
Old Jan 31, 2017 | 04:13 AM
Campy Roadie
The best way to keep a snap ring from flying off is to use the right size tips that are hardened. Cheaper snap ring plier tips tend to flex in the smaller diameters. That said, I keep lever pin snap rings in stock. They usually get bent if you aren't careful to spread them apart just enough and no more. Once they're bent, I don't reuse them.
Old Jan 31, 2017 | 04:32 AM
Sc0-'s Avatar
Sc0-
You will also need it to replace the seal on the shifter shaft on the transmission. It's a tiny little guy....
Old Jan 31, 2017 | 04:41 AM
dixonk's Avatar
dixonk
I picked up a Channel Lock set at Home Depot. It has various tips that come with it and a couple in the pack fit it just fine.
Old Jan 31, 2017 | 04:50 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I happen to have a set very much like the HF set.
I far prefer these over ones with the interchangeable tips because these don't **** and twist the way the interchange types do. Several of the above are very small. If necessary, I could easily file one down smaller, but I haven't found that to be necessary so far.
Old Jan 31, 2017 | 07:19 AM
santajim's Avatar
santajim
HF for me with multiple tips
Old Jan 31, 2017 | 08:20 AM
VA_Larry's Avatar
VA_Larry
Thanks for the replies. I did decide to file down one set of the tips to make them smaller/pointier. This allowed enough grip to get the ring off.
Clutch lever was easy to replace after that. From watching installation videos the brake lever will be a little bit more involved.
Old Jan 31, 2017 | 09:50 AM
BuckeyeUltra's Avatar
BuckeyeUltra
Originally Posted by Jaystn62
I have a Channel Lock brand set that have many different sets of interchangeable tips in straight, angled and 90 degree. Also can be switched from internal to external. I think I paid less than $30 for the kit.
I second that, really like mine.
Old Jan 31, 2017 | 09:56 AM
Buelligan666's Avatar
Buelligan666
Remember to shim your brake lever so you don't break your brake switch.
