Snap ring pliers
Old Feb 2, 2017 | 08:55 AM
  #31
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by caulk04
There's many options out there. I happen to have a Craftsman set that has three different sized handles each capable of internal and external rings and having interchangeable tips etc etc. Very handy...
Perhaps not the help you were looking for, but it's not a specialty thing.
http://www.globalindustrial.com/p/to...placeable-tips
Originally Posted by ohioflhs
Even when I have snap ring pliers, I find it easier to just use a screwdriver. Never had any luck with snap ring pliers.
Using a screwdriver runs the risk of bending the clip sideways and losing it when you have to remove it again......
Originally Posted by leon anthony
there is nothing that will keep that snap ring from flying off into the abess
Being careful and using the correct tip(s) go a long way in preventing that.......
Originally Posted by foxtrapper
When you're taking it off, put your finger over the end of the pin and lift the snap ring up to your finger, then relax the pliers. The snap ring will be trapped between your finger and the pin it's coming off of.
When installing it, put the snap ring against the pin and hold it there with your finger. Expand it and and set it down on the pin. If you slip, the snap ring will be trapped between your finger and the pin you're trying to put it on.
Old Feb 2, 2017 | 08:58 AM
  #32
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by Bone Doc
But, does anyone have a pair of pliers that prevents the snap ring from flying off into oblivion?
TwoBlue02
Feb 10, 2017 01:45 AM
rounder
Sep 18, 2015 03:04 PM
Mr.Softy
Jan 23, 2013 07:08 PM
bfrmbama
Exhaust System Topics
May 12, 2010 11:57 AM
nextorion
Mar 14, 2010 05:01 PM
