Snap ring pliers
Old Jan 31, 2017 | 01:52 PM
VA_Larry's Avatar
VA_Larry
Good tip. Thank you.
Old Jan 31, 2017 | 02:02 PM
470004's Avatar
470004
I use Craftsman Professional retaining Ring Pliers, internal/external. The tips are interchangeable for the different size retaining rings.
Old Jan 31, 2017 | 06:29 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Originally Posted by Bone Doc
Like the others, I have a pair with several interchangeable tips and converts from internal to external snap rings.
But, does anyone have a pair of pliers that prevents the snap ring from flying off into oblivion?
ha ha so true. Put a towel or 2 around your bike and hope it goes flying off onto the towel and not between the pavers like has happened to me.
Mine is from Harbor Freight too.
Old Jan 31, 2017 | 07:01 PM
voodoodrug's Avatar
voodoodrug
i have one from hf,pep boys, and home depo(priced in between but the better of the three)
Old Feb 1, 2017 | 05:32 AM
hd_rolling's Avatar
hd_rolling
I have a set of kobalt from Lowes with multiple tips, I use these very little so the multi tip work perfect and don't take up a lot of space.
Old Feb 1, 2017 | 06:59 AM
1flhtk4me's Avatar
1flhtk4me
I have the same ones.
Old Feb 1, 2017 | 11:22 AM
ohioflhs's Avatar
ohioflhs
Even when I have snap ring pliers, I find it easier to just use a screwdriver. Never had any luck with snap ring pliers.
Old Feb 1, 2017 | 01:35 PM
Lunchboxx's Avatar
Lunchboxx
Originally Posted by VA_Larry
Any tips on where to find snap ring pliers that will remove the retaining ring on the clutch handle?
I have a set of pliers that I've used on other vehicles but the holes in this particular snap ring seem to be too small for the pliers points to be inserted.
Is there a "mini tipped" snap ring pliers that are needed for this?
I bought and used a set from sears that comes with different sized tips.
Old Feb 2, 2017 | 07:41 AM
mainboom150's Avatar
mainboom150
craftsman with changeable tips
Old Feb 2, 2017 | 08:39 AM
leon anthony's Avatar
leon anthony
there is nothing that will keep that snap ring from flying off into the abess
