Chrome Forks
Old Feb 3, 2017 | 08:10 PM
Lotaluck's Avatar
Lotaluck
Default Chrome Forks
Im looking to get chrome forks for my 2012 street glide. I would like to buy the parts a little ahead of time then have my Indy install them. Any advise on what I need to buy, the more I research the more confused I get. Do I just need the chrome forks? Thanks ahead of time.
Old Feb 3, 2017 | 08:22 PM
R.Canales's Avatar
R.Canales
A lot of people here have good things to say about wily shiny (not shure I spelled it right). Check them out. They have an exchange program that allows for you to return your cores within a certain amount of time.
Old Feb 3, 2017 | 08:30 PM
EdwardK's Avatar
EdwardK
Most Indy's have an exchange set. They put their chrome one's on and keep yours to be chromed for the next customer. Check with them and they might have a set and you won't have to buy another and then they can turn it quick. Or they can remove yours, send them to the chrome shop and reinstall.
Either way, no need to buy another set then be stuck with your take offs.
Old Feb 4, 2017 | 05:30 AM
just plain john's Avatar
just plain john
+1 on ***** shiney. I personally haven't used them but I frequently hear good things about them. I would contact them and see if seals are needed, and I'm almost sure they will be. Fork oil too. http://www.willyshiny.com/fork-legs/...ouring-chrome/
Old Feb 4, 2017 | 07:27 AM
NELS's Avatar
NELS
I got my exchange units on e-bay--Impress Plating--Nothing but excellent. Top quality chrome and I didn't have to clean out any bolt holes or sealing surfaces. Can't say enough good about them.
Old Feb 4, 2017 | 10:08 AM
Baeseman1's Avatar
Baeseman1
Not trying to steal your thunder, but I had the same results with Sport Chrome (forum sponsor)
Old Feb 4, 2017 | 10:13 AM
JMC22's Avatar
JMC22
In fact I just got an email last night about a flash sale - you might want to check them out
Use code "VIPFlashSale"
Old Feb 4, 2017 | 03:41 PM
Cygnusx51's Avatar
Cygnusx51
Other than the fork sliders themselves, the fork seals, damper bolts w/crush washers and maybe the drain screw washers (if that model year has the drain screws) will need to be replaced. Those are all one time use parts. If your Indy has those parts then you won't need to buy anything else.
If you're buying all the parts and just having him do the work, go to an HD dealer and get the required fork seals, damper bolt kit and the drain screw kit. Shouldn't need anything else other than fork oil.
Old Feb 4, 2017 | 07:38 PM
RFG7680's Avatar
RFG7680
I'll be the odd man out. The one time we used a chrome things didn't fit right. Too much chrome is not a good thing.
On my 08 SG and my 16 RGS I bought the kit from Harley. Has all the parts you need and has zero miles. It's all new. Not someone's used parts they chromed.
But like I said. I'll be the odd man out.
Old Feb 4, 2017 | 09:10 PM
Lowcountry Joe's Avatar
Lowcountry Joe
I used the Harley Chrome legs. In addition to the innards, you will need new chrome cowbells. Then you will need a new set of chrome wheels, then of course chrome axle nut covers, then polished stainless steel caliper bolts, then .... well that's probably enough for now.
