Are you talking about the stamped emblem? That is pressed in the chrome? there is a sticker one which comes off with a razor blade and Goo Gone. Use the type of razor blade the is bendable. Hold it as flat as possible work slow. Comes off pretty easy. Clean up residue with Goo Gone. Good luck
Looking at the pic of the OP's bike, I believe the subject is the metallic raised lettering on the Street Cannons. I've wondered about that too, I have the same mufflers and thought about removing the emblems, though I haven't tried yet. Anybody?
A friend took his baffles out of his Street Cannons, we replaced them with some Big Louie baffles...
The Script "Screamin Eagle" has three stems on it that go into the muffler body and has a keeper on them... If you remove them, you'll have 3 small holes showing on the side of your Cans...
We had to cut a relief on each end of the Big Louie baffles to clear the stems.
If that's the case he could swap left to right and he wouldn't be able to see the three holes? just a thought or he could do that now and they wouldn't show the lettering either.
most big diameter mufflers have reliefs for the axle - can't swap them.
Originally Posted by gregs1200c
This is what I did with mine.
rk classic
I've never held a set of the street cannons in my hands........
RK Classic are you saying the street cannons don't have any axle reliefs on the mufflers and are interchangeable?
Sorry if I mislead u in any way. I have the standard SE mufflers and they do not have axle reliefs. After looking at several street cannon pics it looks like they do have reliefs on them.
