so... one last time just to make sure I understand... Sena only allows me to communicate with other wireless/bluetooth users and listen to music on my BT device (my smartphone) but if I want to listen to the HD radio then I have to have HD install their 7Pin Din for a wired connection. Is that right?
Does your '17 RGS come with the 7 pin DIN jack to plug a headset into? If not (and I don't think the FLTRXS has it) then yes you would need to get the Boom! Audio Music and Communications Kit (p/n 69200865) installed to use a wired headset. You will also need the dealer to do a software update to your Boom! system. If you intend to use the Sena 20S as the wired headset you would also need the Sena Helmet Clamp Kit for HD
If you want to use a Sena device to communicate wirelessly to other riders and your RGS Boom! system you would need (in addition to the Sena bluetooth communications system) a Sena Freewire and the Sena Micro USB to 7 Pin DIN Cable for HD
