sound system!
Old Feb 21, 2017 | 09:47 AM
harrison1's Avatar
harrison1
2nd Gear
Default sound system!
what's the best sound system for street glide/ road glide?
Old Feb 21, 2017 | 09:49 AM
Buelligan666's Avatar
Buelligan666
You need to check out the audio section of the forum. Tons of knowledge on systems over there.
https://www.hdforums.com/forum/audio-systems-153/
Old Feb 21, 2017 | 09:50 AM
groupw's Avatar
groupw
......... the V Twin
Old Feb 21, 2017 | 10:02 AM
ORradtech's Avatar
ORradtech
As said, check out the audio section and decide what you want to spend, a good system is going to be pricey.
Old Feb 21, 2017 | 10:25 AM
Buelligan666
A "good" system doesn't have to be pricey. A bad @$$ system will be.
Old Feb 21, 2017 | 10:28 AM
JMC22's Avatar
JMC22
You can also score some good used stuff on the classified section here where guys have upgraded and selling their still quality stuff...
Old Feb 21, 2017 | 03:59 PM
Fatherwayne's Avatar
Fatherwayne
Mmmm.... There's lots better brother. No offense intended at all.
-FW
Old Feb 21, 2017 | 04:17 PM
mkguitar's Avatar
mkguitar
Depends on budget- for under $130 you can get infinity kappa 6.5" speakers which mount with adapter rings.
these efficient speakers make very good use of the meager power in the stock radio.
a 2nd common upgrade is an amp such as the rockford fosgate pbr300x2, with can be anywhere for 130 to 160 on amazon- the above speakers work well with this.
some guys want to spend more on amps and many speakers.
..but the best available sound can be from professional level earbuds ( I use shure 535) wired to the stereo. music in and road noise out.
Amazon Amazon
Amazon Amazon
* ignore the polk MM651- a re-design designated MM651-UM will not fit in the fairing.
ignore J&M 7.25"- they are crap, J&M will not provide full specs
mike
Old Feb 21, 2017 | 04:39 PM
Second Wind's Avatar
Second Wind
I spent hours searching this same thing. I just went with the J&M XXR 330 watt system,
I'm not going to win any competitions with it but it's good enough for me and was a simple plug and play install
Old Feb 21, 2017 | 05:39 PM
blackxpress's Avatar
blackxpress
The one I've got. Aquatic AV.
