rear shocks on a 2017
Old Mar 1, 2017 | 01:54 PM
MilesOfTexas's Avatar
MilesOfTexas
If you really want a better suspension, save your money and get Ohlins. The new ones on the 17's will have the same crappy dampening issue as the air shocks. Sure, you don't need an air pump anymore, but it uses nitrogen and as you turn the **** for compensating for ride height, you are making the dampening worse. The 17's only have one 'real' shock on the left side. The right side is a 'dummy shock', similar to the single cartridge in the forks.
Old Mar 4, 2017 | 05:53 PM
08 S Glide's Avatar
08 S Glide
Check out yelvingtonusa.com for the shocks they sell.
Old Mar 4, 2017 | 06:36 PM
checkers's Avatar
checkers
That didn't take long.
Old Mar 4, 2017 | 06:49 PM
smitty901's Avatar
smitty901
Originally Posted by Rbloodworth707
i see thanks maybe i will just buy new ones
Keep in mind that what they did with the front end and the rear at the same time was the major improvement. When I had my 2016 I was going to buy the premium ones. Dealer talked me out of it. He made it clear if I did not do front also I would not be happy with them. He then put me on one that had the first generation premiums and nothing done up front. He was right so I stayed with my air shocks. Then I purchased a 2017 and yes the ride it much better.
Old May 14, 2017 | 09:21 AM
mastergunnera8's Avatar
mastergunnera8
Dont buy the set...Buy the individuals from Jon at Horny Toad HD...for me under $370 shipped...new
They are night and day over the air shocks on my 16 RGU, BUT also change out the front to cartridges (I went progressive monotubes)..the difference is ridiculous..if you have the budget, go ohlin I guess..but for around $750 in parts, I did front and rear...totally different bike...
Good Luck!!!
junior166745151
Air Suspensions
18
Sep 3, 2017 11:05 PM
Rumbles
Nov 27, 2013 04:14 PM
Gotastreetglide
Touring Parts
May 4, 2012 08:01 PM
wix
Aug 10, 2011 12:37 AM
berniemc
Jun 15, 2011 06:28 PM
