on the harley sight i cant find that part number 54000093 it shows 5400008 for the 2015 ultra limited i guess there the same size i found some 2017 take offs on ebay i want to make sure they will work he said they was 13 inch shocks so i guess they will work
Yes. Just make darn sure those take offs are really 2017 and not earlier premium shocks. There is a difference and some have been passing them off as 2017 take offs.
You missing a 0 in the original post. 54000093 is for one shock RH 54000094 is for the LH the set is PN PN 54000008
Am I to understand that these no longer require air pressure?
That is correct. They are referred to as Emulsion Shocks and are adjustable. I know they will fit on my bike. I'm curious if they work better than my current factory air shocks. It would be tough to get worse.
I am sure they are not as good as some of the higher end shocks but every review I have read says there are an improvement over the air shocks. The easy hand adjustment is what interest me as I change between solo, two up and two up loaded quite a bit.
