Using Stainless in Aluminum may yield you bigger problems due to galvanic reaction of the two different metals. That is why the factory uses zinc coated steel.
You don't want to use blue Loctite on the primary bolts. Antisiege is called for
I found some proper size non stainless chrome bolts at ACE. They had stainless, but I passed.
No need for loctite on something like that. I did put some Permatex high temp thread sealant on the bolts.
At least with an allen wrench, if it get rounded off you can grind it down.
Don't always believe the non-critical fastener torque settings, particularly on small fasteners. Some really are tighter than necessary.
I'm in the love torx camp too. I built a dog kennel. The decking screws I bought are torx head. Never slip or strip. Much better than Phillips, square, or the hybrid Phillips-square drive screws. I use my 12v DeWalt cordless impact to remove the bolts from the derby, if I can't break them loose with my 1/4"drive screwdriver handle. I tighten them by hand with the screwdriver handle. My torx drivers are from AutoZone. Better quality than craftsman. I've broke more craftsman brand torx and Allen sockets than I care to admit.
