FYI: You asked and from the sound of things I've installed quite a few more of these than you. And I thought my OCD was bad!!!!
Nope, you are good I got it bad!!!
A substantial part of my OCD was masked over ten years as it was directionally proportional to repetitious work ethics as a Navy F/14A+ & FA/18 mechanic. I'm trying hard every day to adjust to normality, it's a never ending battle LOL...
I'm a old school nostalgic muscle car guy, this is my third Harley, first one changing cams not a custom to roller lifter..... buuuuut old school solid's oh yeah!
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
BTW, the harly lifters are directional. Meaning that the oil fill hole on the side of the lifter needs to be oriented in the correct direction. When you install the lifters in the case bore, the oil inlet port on the lifter needs to face inward toward the cylinders.
Not on a Twin Cam. It only matters if you're reusing them to keep the wear patterns the same. New lifters (excluding woods directionals) can go in either orientation. The lifter bore gets 360 degree oiling to the feed. Even then, it really doesn't make a huge difference.
There were some early manuals that called for them to be "directional" and the bikes wouldn't have them the proper direction from the factory. HD has since revised that to pretty much what I said above.
as I said before. Lifters are directional. at least on the 88ci. Ill consult my service manual on my 103 when I get home from work.
Frankly, that's just incorrect. No matter what some Joe-schmoe youtuber says.
Your 103 manual is going to say what the correct 88cid manuals say: "To preserve existing wear patterns, orientation of the oil hole (inboard or outboard) should have been noted during disassembly."
Not only that, but you can see how the lifter is made, that it will oil the same no matter what way you put it in
