Help: Roller Lifters prep before installing
Old Mar 4, 2017 | 11:00 AM
roussfam's Avatar
roussfam
Originally Posted by liquidr1
as I said before. Lifters are directional. at least on the 88ci. Ill consult my service manual on my 103 when I get home from work.
and survey says....?
Old Mar 5, 2017 | 01:52 PM
B Bop's Avatar
B Bop
Appreciate all your insight, I'm cleaning lifters with acetone, blow dry, submerge in my choice of engine oil Mobil 1 V-Twin 20w 50, followed by liberal coat of assembly lube on cam lobes & inside cam bearings. I agree, over prepping & oiling is a good thing, as I'm not a custom to roller lifters.
Original concern was the lifter roller not rotating around cam lobe, was thinking assembly lube might keep roller from rotating or tracking causing flat spots. That was previously addressed, got it!
Cheers!
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
No man's life, liberty, or property is safe while the legislature is in session.
Old Mar 5, 2017 | 02:02 PM
Big Dave's Avatar
Big Dave
Copy and paste from the 09 service manual
PUSH RODS, LIFTERS AND COVERS
1. Remove any labels used on the hydraulic lifters. Install
lifters in the crankcase bores with the oil hole on the
inboard side and the flats on the lifters facing forward and
rearward. To avoid damage, do not drop lifters onto cam
lobes.
2. See Figure 3-40. Place the anti-rotational pin (4) on the
machined flat between the blocks cast into the crankcase.
Dave
Old Mar 5, 2017 | 04:55 PM
Guntoter's Avatar
Guntoter
I think the only H-D part install more contentious than lifters is the SE vs stock exhaust gasket debate. (Hdforum members are flat out petrified of SE exhaust gaskets btw, for bogus reasons)
I have installed literally thousands of lifters over many years, most were Chevy small and big blocks so no rollers. But the roller just makes the lifter perform better and easier to install and specialized assembly lube is NOT needed on rollers.
Most important thing on lifters is to pre-fill them using a standard small hand held pump oil can you can get anywhere for a few bucks. Use the oil you will be using in the engine, stick the nozzle against the hole in the side of the lifter (has the groove going around it) and pump away till oil comes out the hole in the top seat or you can't pump any more in. The oil running down the side while pumping can be rubbed around the lifter, shoot a pump or 2 in the roller and on the seat and install. That is all there is to it. If you have the assembly lube OCD then use STP on the cam lobes, but oil the roller too.
You don't have to wait to adjust the pushrods on whichever cylinder you start with, but wait about 10-15 minutes before rotating to the next cylinder, or till the pushrods can be turned by hand (after adjustment of course).
Old Mar 6, 2017 | 07:35 PM
B Bop's Avatar
B Bop
I agree with pumping up lifters with oil using "hand held oiler" there is a YouTube video showing this procedure. I located a small size oiler from Harbor Freight just big enough to pump oil into lifter inlet hole. Pump oil overflowing from top of lifter continuously until all air bubbles are gone. Ready to install.
Buuuuut then saw another video showing to clean dry & soak lifters in favorite oil & install. Not sure if option above is an overkill or not should be up to the installer, either way should work fine.
Leaning more towards pre-pumping lifters up...
Any pro's or con's?
B Bop
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Old Mar 6, 2017 | 07:45 PM
skydude426's Avatar
skydude426
I'm no expert mechanic. I'm just a self taught, at home mechanic. I guess I don't see a need to pump up the lifters or soak them in oil. I did a 98" big bore a couple years ago and I just whipped them down, put a little assembly lube on them and installed them. When you start the engine they pump up in a matter of seconds. The assembly lube will protect the moving parts just fine for a few seconds. It might sound like hell but I'm sure it's just fine.
Old Mar 6, 2017 | 08:23 PM
Campy Roadie's Avatar
Campy Roadie
https://www.youtube.com/watch?v=h7ljgWAgb0E
No stock TC88 TC96 TC103 or other Twin Cam lifter is directional. You are are wrong.
Woods makes directional lifters but that's not what we're talking about.
Old Mar 7, 2017 | 10:02 AM
B Bop's Avatar
B Bop
Skydude426 Your probably right! Assembly lube will counter any wear problems for first fifteen seconds of noise emulating from engine until oil is circulated. Buuuut my OCD will now intensify this predicted noise, and now lol... I need to prevent this noise from occurring by over prepping pre-oiling lifters, ha ha ha! Its inevitable!
I do see this though as not a problem to anyone but myself....
I'm a work in progress! "Thanks for every ones help"
B Bop
A politician is a fellow who will lay down “your” life for his country.
Old Mar 7, 2017 | 10:15 AM
SBates08's Avatar
SBates08
Quickest way to oil the system before start up is to pull spark plugs, unplug throttle control actuator and spin the motor over for 15-20 second intervals. Do this until you see oil pressure start to build and your lifters will be primed for the most part. Your OCD has you overly concerned about nothing in this particular situation.
B Bop
Oil Archive (no new posts)
Aug 25, 2022 08:58 PM
johnod
EVO
May 16, 2021 12:48 PM
deuce_streetbob
Exhaust System Topics
Nov 3, 2013 01:05 PM
freebooter
May 5, 2012 01:04 PM
TO34
Mar 4, 2012 10:10 AM
